Old 01-23-2004, 09:03 PM
72ls1 72ls1 is offline
Question Engine Hesitation
I hope that someone can help me. My 98 Grand Am GT 2.4L 5 speed, was running with no problems. I decided to replace the spark plugs with bosche +2 and I started having hesitation problems. I replaced the spark plugs with bosche platinums and it seemed to fix the problem for about a month and now it is back. It has a hesitation only at lower rpm's. I can also feel a hesitation at idle and can be heard.
Thanks in advance
Jeremy
Old 01-24-2004, 08:43 PM
Jpit Jpit is offline
I have had problems with Bosch in the past with my Mazda. I ended up going with the OEM plugs for the car. Yours are AC 41-910. Gap is .060 inch. Check your air filter too.
Old 01-25-2004, 07:19 PM
I was wondering if the Bosch plugs are the problem. I will have to try replacing them with OEM to see if that is the problem.
Jeremy
Old 01-27-2004, 07:50 PM
Re: Engine Hesitation
Today my 98 grand am had a misfire in cylinder #2. This is the second time that this has happened. I deleted the code. Can anyone tell me what that means.
Engine Hesitating when engine is cold Jungleman Trooper | SLX | Bighorn | Wizard 0 03-07-2006 09:11 AM
check engine light on, engine hesitates carloscessna206 Bonneville 1 07-24-2005 03:38 PM
97 V-6 3.8 LaSabre engine hesitation at 40 laurencerj LeSabre 4 12-30-2003 11:32 AM
Engine Hesitation - 2000 Neon jeepinchad 2nd Gen 00-05 0 02-27-2003 09:33 PM
