Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 01-23-2004, 04:57 PM
1viadrft's Avatar
1viadrft 1viadrft is offline
Roll Bar Plans
Does anyone have Plans/Blueprints/Dimensions for a roll bar/cage for a '93 240sx Coupe? I would appreciate any help. thanks.
---1viadrft
Old 01-23-2004, 05:46 PM
ozzy619 ozzy619 is offline
Take it from experiance. unless there's a bolt in kit from some company your better off getting your own mesurements. Theres alot of things to consider one is head room if you have a 6 point cage and you don't measure and hard turn your gonna smack your head into a bar If your Tall. Also Do you want to cage your seats? If you want to properly use a 5point harness instead of stock seat belts your gonna need a crossbar to tie them into also caging your seats means if you have a horrendous accident the causes the care to come apart your safe due to the fact your connected to the cage.
95YJ
full cage with seats and 5point harnesses
SOA suspension
4.11 R&P FOR SALE:$8200
ARB's F/R
OBA system
4:1 terralow T/case with SYE kit
35" Wrangler MTR's
Old 01-23-2004, 05:58 PM
AWDSR20 AWDSR20 is offline
Send a message via AIM to AWDSR20 Send a message via MSN to AWDSR20
From my understanding a role cage further strengthen the chassis of the vehicle by providing support to the cockpit shell. A role cage is usually costume build to the specs of the driver (height, leg room… etc). It’s a simple really ones you’ve seen one, you can figure it out, if you have no moon roof then it is even simpler.
As far as blueprints concern I have no idea were to fined some, I just know that some shops do them relying on the visual appearance of the cockpit.
Check out monkey cage I remember reading about it somewhere?
Hope I helped!!!
Good luck!
Old 01-23-2004, 06:25 PM
1viadrft's Avatar
Re: Roll Bar Plans
thanks guys! Yes, I do plan to use a harness! I already have buckets and a set of harness'! I'm pretty short.... so, I wonder if I can some tips from Japan?
Old 01-23-2004, 07:19 PM
vsiev vsiev is offline
Send a message via AIM to vsiev
Re: Roll Bar Plans
they had some roll cage bolts on for sale on ebay a while ago....it was for the hatchback but i believe they stated it could fit on a coupe too....just keep looking they are expensive though...
The antiroll bar Ris91 Engineering/ Technical 1 10-01-2009 12:10 PM
roll bar and roll bar installation newstanger Non-Performance 5 03-13-2006 07:14 PM
Roll Cage/ Roll Bar 4-Door Flunky '88 - '91 Civic | CRX | Wagon | Shuttlee 21 02-27-2003 04:39 PM
installing Sway Bars/Anti-Roll Bars and Lower Strut Bars..? tsunamiHB Tires and Wheels 5 06-08-2002 04:38 PM
Custom roll bars? Josiah Cars/Parts for Sale/Exchange 0 03-31-2001 12:09 PM
