Old 01-23-2004, 02:50 PM
ixbigybxi ixbigybxi is offline
Wheels Question
I am thinking about getting some 17" wheels. My car is dropped 3 1/4" So I need to know what offsets would work so that they would tuck nice and not rub. And what are the differences in offsets.
Old 01-23-2004, 02:59 PM
mycivic's Avatar
mycivic mycivic is offline
Re: Wheels Question
Positive offsets make the wheel go outwards and negative offsets make the wheel go inwards. I think...
2003 Honda Civic LX
Mods: Bone Stock
Old 01-24-2004, 05:36 AM
So what offset would I need that wont rub. Someone please help.
Old 01-24-2004, 08:15 AM
SiZ's Avatar
SiZ SiZ is offline
Re: Wheels Question
+45mm
"The nympho of info, I'm fuckin' what ya heard"
Old 01-24-2004, 08:35 AM
9civicsi1's Avatar
9civicsi1 9civicsi1 is offline
Send a message via AIM to 9civicsi1
I had about a 4in drop and then I got some 17s
I figured id get a camber kit to help out so i didnt ruin my tires. I put it on and took it to get aligned. what i then found out is a piece of the subframe needs to be notched out so the upper a arm can swing by. i dont have any pics of where it needs notched out but ill try and get some. so i got my camber on and my car was still dropped about 4 in. i didn't scrape but my tires rubbed the wheel wells so i raised it and got realigned. its pretty low as you can see in the pics and it wont scrape most of the time unless i hit a bigger bump goin pretty quick. still when it does rub now it wont bend the fenders or anything the wheels are 17x7 with a 40mm offset
www.cardomain.com/id/9civicsi1
www.streetsourcemag.com/myhatch
1991 Honda Civic Si
Old 01-24-2004, 02:59 PM
Re: Wheels Question
So does +45 stick out on the sides further than a +40
Old 01-24-2004, 03:03 PM
GTA's Avatar
GTA GTA is offline
Whee..
Re: Re: Wheels Question
nope. lower offsets stick out more. you need a +40 or higher to tuck with a 17.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 01-24-2004, 03:28 PM
BullShifter's Avatar
Re: Re: Re: Wheels Question
offset/backspacing is the distance from the wheels mounting point to the edge of the rim or the distance from the mounting surface to the center line of wheel.
Offset & backspacing are 2 different things often confused, even wheel site call it offset when its backspacing . . .
Old 01-24-2004, 03:43 PM
SiZ's Avatar
SiZ SiZ is offline
Re: Wheels Question
I think even a 40 would rub with 17s and a 3.25" drop.. I've had 38 15" rims and they rubbed, and my +42 C8s are very close to rubbing (but not quite)...
To be safe, stay in the 42-45 range.. 45 being stock and most ideal.
Old 01-27-2004, 12:29 AM
Re: Wheels Question
Thanks for the help everyone I understand now.
96 Eclipse 2.0 Manual Wheel Bearing Question AdrianT Eclipse Problem Diagnosis 1 09-20-2010 08:05 PM
14 inch olds wheel question- help! lakesidebluexpy General Discussion 1 12-22-2002 05:48 PM
240 wheel questions TEIN240 Tires and Wheels 2 10-11-2002 11:21 AM
18 in. wheel question... Nismoboy1 Cosmetics 2 12-18-2001 01:45 AM
wheel question Shobo General 2 09-25-2001 07:37 AM
