Old 01-23-2004, 11:14 AM
AdvanTech's Avatar
AdvanTech AdvanTech is offline
Lightbulb Head Work
There are many things to consider when building a high performance head:
Myth: A head with higher flow bench numbers will perform better than a head with lower flow bench numbers.
Reality:This is not always the case. If you make a port big enough to make big numbers on the flow bench, you might not realise that you are slowing down the speed of the air travelling through. So the best setup would be make the ports big enough without sacrificing too much port velocity.
Nitrous engines like big exhaust ports, but imagine how your engine would run when youre not using it.
If you make a port really big on a turbo engine, it creates more turbo lag, and creates idle and driveability problems on street cars.
Also, when port-matching an intake manifold to the head, make the entrance of the intake a bit smaller than the head. This will help with reversion during overlap, especially with cars that run nitrous.
Do not put a bgger valve on your head unless you are going to port the bowl to the same size as the valve. And sometimes with too large of a vlave, you can hurt flow because the cylinder bore will shroud the valve.
And also think about what cams you will be using because the intake and exhaust valve might touch each other during overlap.
Thats all I have, so please add on if I missed something, or did not explain well enough.
Old 04-06-2004, 05:15 PM
GsR_95 GsR_95 is offline
Re: Head Work
Yea I Have Crowers Drag Cams And I Have To Build My Head. Im Doin A 3 Angle Vavle Job, Port Polish, Upgrade Ecu, And Shoot Nitrous Later On. Im Paying About 1500 For The Job, Wat Do U Think?????
Old 04-06-2004, 05:32 PM
AdvanTech's Avatar
Re: Re: Head Work
lol It's been awhile since I made this post
PM sent
Will
Head work suggestions jbparrothd21 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 11 02-05-2009 12:24 AM
Will this head work? doug294 '88 - '91 Civic | CRX | Wagon | Shuttlee 6 02-05-2004 10:48 PM
looking for more power head work 22re porky Pick-Up 0 01-22-2004 05:01 PM
would a gsr head work on a zc Jetts '88 - '91 Civic | CRX | Wagon | Shuttlee 3 03-07-2003 07:03 PM
Advice on head work JD@af General Discussion 9 03-25-2001 05:19 PM
