Go Back   Automotive Forums Car Chat > Chrysler > PT Cruiser | PT Cruiser Convertible
Old 01-23-2004, 07:51 AM
comp comp is offline
2.4 cam timing
i see this site does get a lot of action but; HAS ANYONE FOUND OUT THEIR CAM TIMING WAS OFF FROM THE FACTORY? shot in the dark
Old 03-09-2004, 02:16 AM
Anaudiophile Anaudiophile is offline
Re: 2.4 cam timing
Hmmm........not very likely, but could be possible. If it was out even one tooth on one cam, you'd notice quite a difference in driveability!!
Old 03-09-2004, 12:24 PM
my dad's is a full 1-1.2 seconds slow 0-60 mph ??? you can feel torque
band start then the computer shifts and you feel it start to come on and it shifts again
Old 01-11-2005, 06:52 AM
Bigs30Abone Bigs30Abone is offline
Re: 2.4 cam timing
Unlikely that the cam timing is off but would not hurt to check it. You can also put a vacuum gauge on car, if cam is out vac will not be what it should at idle.
Old 01-11-2005, 08:07 AM
they have put 20k on in and it's out of warrenty now
2003 eclipse 2.4 cam crank codes check engine light polarisxcr Eclipse 2000+ 9 08-02-2012 06:39 PM
2.4 blowing black smoke cr_rider Mighty Max 5 12-31-2010 03:56 PM
2.4 cam actuator valve change jim krisher HHR 1 12-14-2010 03:16 PM
Nissan Quest V6 to 2.4 ltr 4 cylinder swap Scraped Knuckles Quest | Presage | Serena 4 02-20-2009 09:59 AM
Honda Passport 4-cam timing problems olderguy How-To's and Walk-Through's 3 02-04-2006 02:20 PM
