Old 01-22-2004, 10:30 PM
jkdoranski jkdoranski is offline
89 s10 wont start
its a 4.3 v6 fuel pump runs. engine will turnover. almost started then died. tried fluid in "carb" didnt work. do you have any suggestions. thanks
Old 01-22-2004, 10:32 PM
Re: 89 s10 wont start
i dont know if it worked buit it is a 4.3l fuel pump runs. put fluid in "carb" didnt work. any suggestions thanks
Old 01-23-2004, 09:30 PM
dbone1200 dbone1200 is offline
is it getting any fire.
Old 01-25-2004, 08:08 PM
okay coil ignition is good so is the distributer. the spark wires are ok. the spark plugs have spark. the battery is good and a new starter. put it still wont start what else could be wrong thanks
Old 02-12-2004, 12:42 PM
jeffstruck jeffstruck is offline
Re: Re: 89 s10 wont start
If your sure the coil is good (you could have spark but not enough or intermittent) then I would go to the ignition module and have it tested.
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
88 s10 wont start when cold knuclemul S-10 4 03-15-2004 07:40 AM
89 s10 wont start jkdoranski Engineering/ Technical 0 01-22-2004 10:28 PM
s10 wont start paul r. S-10 2 02-28-2003 08:15 AM
