Old 01-22-2004, 09:16 PM
blacksheep blacksheep is offline
Send a message via Yahoo to blacksheep
sumtin wrong with the car ? ? ? ? ?
driving home one day my car started to run ruff like it was out of balance or missfiring, and sundenly shut of it will crank over and will not start, the injectors work, the camshaft timing is correct, all cylinders have a compression between 175 185 psi, but i think the ignition timing is bad and was wonderin if theres a way to check when the engine doesnt start, the rotor in the distributor cap is good so any help would be nice too find out what went wrong ?????? coil possibly went bad
it better get me to wyoming
Old 01-23-2004, 01:07 AM
BullShifter's Avatar
Re: sumtin wrong with the car ? ? ? ? ?
Sure the coil could have gone bad. . .any time a car doesn't start you always check to make sure it has gas in the tank, fuel pressure @ engine, battery current, & verify for spark. If you tell us which one the 4 is missing then we will be able to assit.
Ingnition/electrical
http://www.binghamtonlife.com/manual...electrical.htm
Fuel
http://www.binghamtonlife.com/manual..._emissions.htm
is it me or there's something wrong with the car Aurora_Alpine Aurora 1 11-07-2006 07:07 AM
what the hell is wrong with my car Mexican619 Eclipse Problem Diagnosis 2 09-12-2005 11:12 AM
What the hellis wrong with my car? kristi498 Grand AM 1 12-30-2004 05:53 PM
My friend and I went to the track.He ran some slow times.What is wrong with his car? RocketStang911 Mustang Talk 8 06-25-2004 01:07 AM
so what the f is wrong with my car 1969Stang Engineering/ Technical 5 02-26-2004 01:03 AM
