Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 01-22-2004, 08:14 PM
plagueofme plagueofme is offline
Problem with Audio security feature
I recently bought a used 2000 Eclipse. I just had some work done on it, and apparently when the battery was disconnected, the sound system went into some sort of security mode. When I attempt to turn the stereo on, the display says "OFF". Has anyone encountered this, and if so, what did you do to fix it?
Thanks for your time,
-plagueofme
Old 01-22-2004, 09:21 PM
Rulez Rulez is offline
Send a message via AIM to Rulez
Re: Problem with Audio security feature
There is a code you have to put in to reset it. If it's not somewhere in your manual, ask the person you got it from. Otherwise, take it to the dealer.
Mike Rule
2000 Mitsubishi Eclipse GT Turbo
www.club3gfl.com
www.fiautosports.com
Old 01-23-2004, 11:11 AM
eclipseGTO's Avatar
eclipseGTO eclipseGTO is offline
It's not in the manual. It's on a card and you should have got that card from the dealer or the person you bought it from.
Old 01-23-2004, 01:41 PM
Right, but the card is usually in the manual somewhere. Thats what I meant.
Mike Rule
www.club3gfl.com
Old 02-03-2004, 02:24 PM
Security Woes
The card is nowhere to be found. I took it to the dealer and got the code, but I was told that I have to run the radio in the "Off" mode for up to two hours to get it to unlock, so that I can enter the code. It's been about an hour and 20 minutes now. Driving is really boring when it's so quiet.
Thanks for your help, everyone.
-plagueofme
problem with motor turning over and cranking midblu Problem Diagnosis 3 05-11-2010 06:49 PM
2005 Silverado problem with audio source switch Bikerjw Silverado 0 02-22-2007 11:01 PM
Battery problems with audio EQ mikeisoffthehizzle Car Audio 5 01-17-2006 09:51 AM
Help... I'm trying to make a video of my car... problem with audio. flatlander757 Car Videos 2 09-22-2005 03:14 PM
