Old 01-15-2006, 04:53 PM
mikeisoffthehizzle mikeisoffthehizzle is offline
Battery problems with audio EQ
I really don't know what the problem is, but i still have my factory battery to my 2002 chevy silverado, ext cab and i have a 450.2 channel Bridged kicker KX amp, and 2 kicker comp vr 12's wired for both voice coils, and a pioneer DEH-P8MP cd player set to 40 watts, instead of 60. I also have projector head lights, with halos and LED lights installed, i figure i'm using so many watts that its draining my battery. The first time i installed everything my truck wouldn't start so i figured maybe it was a kink in the battery wire, bad fuse, or maybe bad connection but everything proved to be OK because the next time i installed it everything worked just fine till i turned my truck off. I let it sit with the cd player and subwoofers going for 7 seconds then opened the door, which shut them off, went inside a resturant to order and came back out minutes later and my truck wouldn't start until i started wiggling the wire. Yesterday i bought a new battery and installed it, but i was wondering if this be just a bad connection? And what would be the best solution? i.e. stingray alternator, or a capacitor(correct spelling?)
Thanks!
Old 01-15-2006, 07:22 PM
ImportBuilder's Avatar
ImportBuilder ImportBuilder is offline
Send a message via AIM to ImportBuilder Send a message via Yahoo to ImportBuilder
Re: Battery problems with audio EQ
Sounds like something is killing the battery while the truck is off. Does the amp have a remote wire?
Now Playing:
1x Pioneer DEH-3800MP HU
2x Majestic MCS650BC
2x Majestic MCS6923BC
4 AWG Power/Ground
1x Lightning Audio STRIKE S4.15.VC2
1x Lightning Audio STRIKE 24.500.1
Dynamat Xtreme in trunk
Coming Soon:
New SPL Setup
Old 01-15-2006, 08:03 PM
vinnym86's Avatar
vinnym86 vinnym86 is offline
Send a message via AIM to vinnym86
dont get a cap, check for power drain while off, upgrade Big 3, and after all that, if necessary, buy a new alt.
The most beautiful thing we can experience is the mysterious... He to whom this emotion is a stranger, who can no longer pause to wonder and stand to rapt in awe, is as good as dead: his eyes are closed.
Old 01-16-2006, 10:20 AM
Jet-Lee's Avatar
Jet-Lee Jet-Lee is offline
Banned
Send a message via AIM to Jet-Lee Send a message via Yahoo to Jet-Lee
Big 3? Cables, Alternator, Battery?
methinks you have a remote wire connected to a hot wire.
Old 01-16-2006, 11:05 PM
dave92cherokee's Avatar
dave92cherokee dave92cherokee is offline
I agree you probably have the remote wire connected to a constant 12v keeping the amp on at all times. When you are driving with the lights on at night and the system cranked do the lights flicker at all. If they do then you DEFINATELY need to get a cap as that IS draining your battery faster than your alt. can recharge it. I have never had, never installed, never recommended, never will install a system without at least a 1 farad cap. and anyone who does better have a good bit of money to keep buying batteries and charging them and buying more powerful alts.
Old 01-17-2006, 09:51 AM
Jet-Lee's Avatar
Banned
Get a better alternator before you think about getting a cap.....in which case should be passed up and another battery put in its place if the alternator doesn't do the job.
Why do you think SPL competitors use full size car batteries instead of caps?
