Old 01-22-2004, 07:28 PM
exwane exwane is offline
headlights won't go off
I have a 96 grand am, and my headlights won't go off. It is not the DRL's, it is the regular headlights and they stay on day and night as long as the key is on. Any ideas how to fix this or disable the automatic headlight control?
Old 01-23-2004, 10:05 AM
Chameleon-kat's Avatar
Chameleon-kat Chameleon-kat is offline
Send a message via AIM to Chameleon-kat Send a message via Yahoo to Chameleon-kat
Re: headlights won't go off
I would guess problem might be with sensor for DRL's . Covered, dirty, or just not working right. Mine doesn't always work correctly either. If you have stock radio, does the lighted dial sometimes show bright (daylight setting), and sometimes less bright (night setting) during the day? I think that would point to sensor (or DRL circutry) also.
Old 01-26-2004, 04:01 PM
can anyone tell me where the sensors are? I think they may just be dirty, because it works properly sometimes(rarely) when the sun is very bright.
Old 01-26-2004, 05:35 PM
Overtime's Avatar
Overtime Overtime is offline
Send a message via AIM to Overtime
Looking in my Haynes manual, all I can find is a wiring diagram. I'll check tomorrow, but if you'd like to get out and look before then, the colors on the wires are Yellow/Black and Light Green/Black (I'm assuming it means black stripe).
Old 01-27-2004, 06:01 AM
I believe the sensor is on top of the dash (somewhere), I have yet to find it, but I suspect it might be sorta inside the defrost vents.
Old 05-05-2004, 10:45 PM
Shadivak Shadivak is offline
Same problem on my Grand Am. I replaced the DRL sensor, which is in the defrost vent on the passenger side. Still, headlights are always on. Anyone know how to fix this annoying ass problem?
Old 05-06-2004, 04:44 PM
e2helper e2helper is offline
Are your headlights ALWAYS on or just when ignition is on?
Old 05-06-2004, 06:17 PM
Whenever ignition is on, whether the car is in drive or park or not started. Only clicking parking brake once turns them off, but I don't like driving like that and would like to fix this damn problem.
Old 05-06-2004, 07:26 PM
mikewohlford mikewohlford is offline
I dont know if the 1996 GAs are equipped with this, but I will ask anyways. Try checking the stick to either the left or right of the steering wheel. My 2003 grand am stick (the opposite of the turn signal stick) has 3 options. 1) Auto (sensor) 2) Always on, and 3) no idea. (i assume that this one just turns on the dash lights) Try checking that. Your car may has a switch that slides back and forth. Mine turns. Good luck.
Michael W.
Old 05-06-2004, 09:06 PM
Shadivak, based on your description, even though you already replaced the DRL sensor I would have to say your vehicle thinks it is dark outside. I would have to guess that you have a wiring problem with circuits that go to the DRL sensor or the module that controls that function. Sorry, I don't remember too much about the module other than I think it is attached to the driver dash close-out panel
94 Lincoln Continental: Lights won't turn off TheWampusCat Continental 8 01-12-2014 10:56 AM
Headlights turn off when A/C turned on. Assassin85 Grand Prix 5 08-13-2010 09:34 AM
Headlights won't turn off! jtavares Grand Cherokee | Grand Cherokee SRT8 3 06-05-2004 04:12 AM
Headlights won't turn off kromedge General Discussion 4 05-03-2004 08:21 AM
Headlights won't turn off. Helios_c7 Celica 3 03-22-2002 04:26 PM
