Go Back   Automotive Forums Car Chat > Plymouth > General Discussion
Old 12-28-2003, 04:55 PM
kromedge kromedge is offline
Headlights won't turn off
Help!! My 1990 Acclaim is posessed!! I was driving along when I noticed my high beam indicator was on. Not so weird except for the fact that my headlights were shut off. When I got home however and turned the car off, the headlights remain on as well as the high beam indicator. The only way I can shut them off is to disconnect the battery. Any help to resolve this one would be greatly appreciated.
Thanks
Old 04-30-2004, 11:39 AM
mjburger mjburger is offline
Re: Headlights won't turn off
I have the same problem with my 90 ford aerostar van...
Have you found a solution?
Thanks
Old 04-30-2004, 01:34 PM
slantsixness's Avatar
slantsixness slantsixness is offline
your high beam switch is stuck in the flash-to pass selection. Probably you could excersise the switch and it'll go away, but if not, it should just be the hi-beam switch, or you have a melted wiring harness.....
Let's hope it's not that....!
Good luck,
Slantsixness
If I knew what I did to break it, I would've known not to do what I did.
www.classicwinnebago.com
Old 04-30-2004, 02:42 PM
Re: Re: Headlights won't turn off
Thank you for your input... I try and work the switch if not take it apart.
That's quite a name...
I used to have a slant six in an old dodge... it was bulletproof..
Martin
Good luck,
Slantsixness
Old 05-03-2004, 08:21 AM
I'm actually quite insane about the slant six! I'd put it in a new car if I could. definitely bullteproof. I've Had at least one slant six car or truck all my life, including my parent's cars when I was a kid!
I have one of the latest and last ('82-'89) slants in my 400k+ mile '86 truck, and its still going as strong as ever!
My project (hobby) car is a '69 dart that's a slant six car right now too.
Gotta love anything that lasts that long!
Slantsixness
94 Lincoln Continental: Lights won't turn off TheWampusCat Continental 8 01-12-2014 10:56 AM
'99 S-10 Extreme - Headlights won't turn off GIGIDAY S-10 1 08-13-2004 02:51 AM
Headlights won't turn off! jtavares Grand Cherokee | Grand Cherokee SRT8 3 06-05-2004 04:12 AM
My passenger side Headlight won't turn off? HELP Rodeorulz Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 06-03-2004 08:11 PM
Headlights won't turn off. Helios_c7 Celica 3 03-22-2002 04:26 PM
