Old 01-22-2004, 06:47 PM
schofell84 schofell84 is offline
Send a message via AIM to schofell84
Unhappy tons of heating problems
ok, 94 lesabre custom ...
heater randomly turns off and stays off for short periods of time, a couple minutes often. i found once on a long trip where it actually worked it got extremely hot. also there is a coolant smell in the car, possibly a heater core problem?
gimme a hand, thanks.
Old 01-23-2004, 06:37 AM
comp comp is offline
on the smell, real good chance, on the on-off , see if the blower is on a
fuse or a breaker, breakers sometimes get weak and do that,it can also
be a loose connection to fan, if auto temp
Old 01-23-2004, 08:05 AM
pcv pcv is offline
First of all, check the coolant level in the radiator when the engine is cold. If it is low,top it up and get the vehicle checked for coolant leaks. If the coolant is good and full and no leaks are present, i'd replace the thermostat and go from there.
Good luck.
NOTHING LIKE AN OLD CAR.
1994 voyager ac and heat problems bitco Caravan | Voyager 2 10-20-2009 08:49 AM
2000 Chevy 1 ton 454 problems glewis Silverado 7 08-04-2007 06:14 PM
New Catalytic Converter. Now tons of problems. Please help!! JeffChalupa '97 - '03 1 06-05-2007 10:04 PM
1998 1 ton transmission problem smccatv Express | G Van 7 03-13-2006 08:23 AM
91 tons of problems PLEASE HELP! grasshoppa05 '88 - '92 0 05-31-2005 08:10 PM
