Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 01-22-2004, 05:38 PM
91LSspecial 91LSspecial is offline
check engine light after swap!!!?
ok my friend took him civic to some guy to get his d16ysomething, swaped out for a d15b, alittle better engine.
my question is about the code we pulled fromt he civic, the code was 23=knock sensor or circit. dose the d15b have a place for a knock sensor, and if not what do we do, and if so are there problem areas for this to fail.
also i wasent there but the mechanic showed him an electrical plug in that he could not find a place for. we look to see if we could find it agian, but couldnt(it is supposed to be under the intake manifold) and i didnt want to start ripping stuff off if there is an easier way. Any suggestion would help, expierance much needed.
Old 01-22-2004, 06:33 PM
EKCivicVTEC EKCivicVTEC is offline
Re: check engine light after swap!!!?
ok..im the friend and i have 96 ex coupe..which came with a d16y8,i blew that motor and swapped in the jdm d15b vtec.i have a check engine light,and i pulled the code..it said it was the knock sensor,i was told there is no place to plug the sensor in on the jdm engine.What can i do with the knock sensor to get rid of the check engine light.
Old 01-23-2004, 12:11 AM
YOUNGSTER YOUNGSTER is offline
Send a message via AIM to YOUNGSTER Send a message via MSN to YOUNGSTER Send a message via Yahoo to YOUNGSTER
are you using the jdm ecu also and i thought i heard of one of my freinds haveing the same problem and they fixed it by reflashing the timining or something like that i dont remmeber exactly
MODS: Motor :jdm b16 block, itr head, skunk 2 cam gears, msd ignition, intake, exhaust, straight pipe, skunk 2 ecu. act race clutch Suspension : grnd cntrl coilovers, 4 way adj shocks , spoon strut bar, skunk 2 sway bar, itr control arms, energy bushings misc. : super nice jdm seats, momo detachable steering wheel, Jdm clutster, Spoon Cf duckbill wing, vision smoked amber turn signals. COMING VERY SOON IN DAYS LS vtec ARP ROD BOLTS HEAD BOLTS AND 75 SHOT OF GIGLE JUICE look in my galler
Old 01-23-2004, 02:49 AM
no it si the usdm ecu, also the computer is automaticlly retarding the timing because of the knock sensor malfuntion, so seting the timing over agian would cause the ecu to retarding the timing agian. if i am wronge, explain
Old 01-31-2004, 05:16 AM
DrunkenTiger84 DrunkenTiger84 is offline
yes there is no place to plug in the knock sensor becuase it is jdm. jdm doesnt come with ks because of emisons and does ur vtec work if it donet then its becuse of the ks i think. not positive though
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
