Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-22-2004, 05:26 PM
Evil_Incarnate Evil_Incarnate is offline
2000 Jimmy Blowing warm to cold
I have a 2000 Jimmy and the heater suddenly will blow cold air, sometimes it blows hot, somtimes it blows luke warm. It blows, but the air is never always hot. Any ideas... Need more info?
Old 02-05-2004, 09:34 AM
poorgrandma poorgrandma is offline
Jimmy Heating
Mine's Doing The Same Thing--i Noticed It Would Get Warm At Sustained Speeds Of 70-80 Check Out The Post Re: Do I Need A Reverse Flush On Heat System? I Haven't Tried It, But I Am Going To.
Old 02-05-2004, 09:46 AM
xjoeharperx xjoeharperx is offline
Send a message via Yahoo to xjoeharperx
Re: 2000 Jimmy Blowing warm to cold
sounds like a problem in the heater control valve...you may have crud built up like the lat post ...or may have a vacuum supply issue to the valve...
Old 02-05-2004, 03:47 PM
alienmagic alienmagic is offline
Mine was doing something similar to that. I recently flushed out the Dexcool really well and replaced it with 50/50 green Prestone and the heater has been working much better so far.
Old 01-23-2005, 03:18 PM
trout-man trout-man is offline
Jimmy SLT heater blowing warm to cold
My 98 Jimmy was doing similar. I had changed the antifreeze last fall the radiator was very clean, so I didn't flush it. Recently the heater would not blow hot air. I noticed the thermostat was running about 160 instead of normal 195 so I replaced it, but that didn't fix the heater problem. After reading through the post on Automotive Forums, I decided to flush the heater core with a water hose. That fixed the problem. The heater will get as hot as you want now. Thanks to all who post problems and successes here.
2000 jimmy slt 4x4 rear running light out (Bulb is good) Lonnie 4x4slt Problem Diagnosis 1 02-11-2010 07:55 AM
1995 Jimmy misfires when cold reed92 Problem Diagnosis 11 01-17-2010 09:32 AM
a/c blows ice cold, then warm, then jessispop Envoy 2 11-07-2004 03:11 PM
pass. side blows cold/drivers blows warm stickboy101 Aurora 12 11-05-2004 03:02 PM
96 accord a/c starts cold but fans cut off and blows warm joeramirez Accord/TSX/Accord Hybrid 5 06-15-2004 06:42 PM
