Old 01-21-2004, 05:39 PM
ChrisNJ ChrisNJ is offline
supercharger oil??
would just like to check it, in case it needs any? manual doesn't say what kind, just GM#................ my guess is that if it doesn't leak, it should be fine, kinda like a rear. just curious what kind of oil? thx
Old 01-22-2004, 06:21 AM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: supercharger oil??
GM makes a supercharger oil, see your dealer. The manual doesnt say it, but SC oil, just like motor oil, breaks down over time, it is proper maintenance to change the sc oil about once a year. Use a small turkey baster to siphon the old oil out and fill with new. Fill to the botttom of the threads in the fill cap. It should accept about 2 and a half bottles.
Old 01-22-2004, 02:24 PM
Thanks tman, I will change it. I was kinda hoping it would be some std. oil. It probably is, hope gm's rebadge isn't $20 a quart?
Old 01-22-2004, 03:49 PM
tman's Avatar
Pimpin' ain't easy
no, its in a little minibottle, I think its 10 bucks a bottle though. I could be wrong.
Old 01-29-2004, 03:37 PM
it was 7.95 a bottle, got three, was easy to change with the turkey baster, thx. was dirty too, probably original, but she has 100k on her and still sounds great. only could get 50cc out, or about 1-1/2 bottles, put the same back in, to the threads.
Old 01-30-2004, 11:16 AM
comp comp is offline
if you allready got extra left over ,run it for a week or two and pull enough out to finish up extra, you'll be doing a little bit more cleaning
and open oil does have a shelve life so it will go bad
Old 09-29-2004, 08:25 PM
PAPA Man PAPA Man is offline
I checked my SC oil and couldn't get any to come out with turkey baster. So I added a bottle and still didn't see any come out. SC seems to work fine...should I be concerned? Maybe I'm using a bad turkey baster to remove fluid?
Old 09-30-2004, 05:47 AM
deadring deadring is offline
4.50$ CDN here for the botles.. the guy told me i only need 1 bottle.. like 4 oz or soemthing.. i stil bought 2 anyways..
Old 09-30-2004, 06:21 AM
tman's Avatar
Pimpin' ain't easy
sometimes, the oil is thrown from the bearing, emptyying the oil "sump" if you will. Just fill it up and you'll at least be better off than you started.
Old 09-30-2004, 07:58 PM
"sometimes, the oil is thrown from the bearing, emptyying the oil "sump"
can it end up in the intake rubber tube ?? coze mine seems to have some.. but it's been there a while.. it's all sticky and brown...i changed my SC oil today and what a diffrence! the old one was almost black.. the new one is crystal clear.. the turkey baster worked great!..i couldn't use the shop-vac at the time so..
Old 09-30-2004, 08:41 PM
tman's Avatar
Pimpin' ain't easy
It usually doesn't splatter, but more like leaves an oily deposit on the snout of the SC. I'd imagine it could, if the bearing went bad.
Old 10-01-2004, 06:50 AM
yeah that what i though, but the oil was not fresh...it was sticky..like pitch..and just stayed there.. but it was full when i opened it up...too full if you asked me.. so if you get pressure in where the oil is and run it at high rpm you get even MORe pressure... just like in a gear box..so the oil has to go out from where..i got an old snowmobile here and i changed the gear box oil... and i think i put a littel too much.. when i was going 60 the oil was getting out by the breather.. until the "too much" was all gone.. then all was ok
so i assume that, since the car is 80 000 miles, that the oil in the super charger is brown..almost black but STILL full..and the last owner never heard of changing the oil in the SC and he had it for the last 10000 miles...the Sc doesn't make noise at all.. the deposit in the intake.....if i add all this up it tells me that : the cars first owner, must have had a problem with the original SC that must have blown bearings or something...and must have gotten it fixed.. and now, it was due for some new oil...because if there was SC deposit in the intake..and it was still full..then it,s not leaking anymore.. right?
Old 10-01-2004, 07:45 PM
vljenewein's Avatar
vljenewein vljenewein is offline
Banned
Send a message via ICQ to vljenewein
What about synthetic oil for this beast? How thick is the viscosity? Close to 90W oil? Looks like something better could be drummed up. Even a bit of "blending" might be good for this application.
There is a great lubrication that has tremendous shear properties and it is available at WalMart. I've seen videos of engines under power and LOAD, running with NO oil after this stuff was circulated in the engine. Thest was done at Univ of Nebr. testing labs.
changing the supercharger oil 95RIVER Riviera 2 05-12-2004 08:55 PM
Topping Up Supercharger Oil gtpguy Grand Prix 6 04-25-2004 12:49 PM
Supercharger Oil Level Check '98 Bradical Regal 2 03-15-2004 08:22 AM
supercharger oil GTPpower Grand Prix 5 10-30-2003 10:17 AM
supercharger oil change gtp 2000 Grand Prix 3 10-19-2003 04:35 PM
