Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 01-21-2004, 05:08 PM
bigwar bigwar is offline
Heater only blows cold in 95 Caprice station wagon
95 Caprice Station Wagon with a/c.
About 3 weeks ago I noticed no warm heat blowing out of the heater.
[This was before the big artic freeze hit us in the Northeast.]
Motor blows strong but no heat in any selection (def,floor,vents, etc.)
I checked radiator level: fine...
What could be causing this lack of heat?
Old 01-21-2004, 05:19 PM
burnM's Avatar
burnM burnM is offline
Re: Heater only blows cold in 95 Caprice station wagon
Thermostat stuck open, Dirt on the a/c evaporator blocking flow of air, incorrect mixture of water/prestone,stuck valve on heater core hose.
Check those and see....
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
Old 01-22-2004, 01:19 AM
Re: Re: Heater only blows cold in 95 Caprice station wagon
Will do. Thanks.
Old 01-25-2004, 08:50 AM
351c 351c is offline
flush heater core with garden hose both directions
Old 01-27-2004, 12:33 PM
oinkr2 oinkr2 is offline
Here's another vote for flushing the heater core. These cars came with Dexcool and the factory added clay tablets to the cooling system. On several occasions the heater core on our 96 has become clogged. Take the hoses loose and gently flush both ways through the heater core and you should flush out the debris. Be sure to bleed the air from the system when you hook it all back up as a air pocket in the cooling system will give the same result and when you bleed the air out, don't let any coolant get on the optispark.
Wade Jordan
Front Royal, VA
'03 Sierra regular cab, long bed, WT, LR4, 5-speed
'96 Impala SS DGGM
Heater starts blowing cold air on passenger side? BDeHaven13 TrailBlazer | Trailblazer EXT 3 03-10-2010 10:14 PM
Help-Heater only blows cold air (rear) papichuloy2k Durango 3 08-18-2009 02:32 PM
2000 Envoy heater only blows cold air Cityboy2468 Envoy 2 01-30-2008 08:34 PM
Heater only blows cold air.....totally stumped vashthestampede Envoy 8 01-23-2006 06:25 PM
1988 caprice station wagon... too much power??? Jeremiah's88 Caprice 1 03-20-2005 04:43 PM
