Old 01-21-2004, 05:04 PM
rambur's Avatar
rambur rambur is offline
Send a message via AIM to rambur Send a message via MSN to rambur Send a message via Yahoo to rambur
'00 Tahoe, headlights always on, no DRL
Hey all,
I have a '00 Tahoe LT (new style) and since buying it, the headlights are always on, day or night, when running... it doesn't switch over to just DRLs. Has anyone else had this problem? Is there a fuse or relay that controls this which may be bad? Or might the light sensor on the dash be bad? Thanks for any help.
Mark
Old 02-04-2004, 11:01 AM
happyguyy2k happyguyy2k is offline
Thumbs up Re: '00 Tahoe, headlights always on, no DRL
Try programming the lights by pressing the dome overhead 4 times in a row you will here a chime.
Robert
Originally Posted by rambur
Hey all,
Mark
Old 02-15-2004, 10:11 AM
rambur's Avatar
Re: Re: '00 Tahoe, headlights always on, no DRL
Robert
That didn't change a thing. I've looked at the fuses and relays that are for the DRLs and headlight, but nothing appears wrong there. Is it likely that the photo-sensor on the dash is bad? Or might there be something else that'd cause this?
Old 02-16-2004, 10:04 AM
The Hoe The Hoe is offline
I assume you have talked to the dealer? I have an 00 and that doesn't happen to me.
Old 02-16-2004, 10:58 AM
Jeremy-WI Jeremy-WI is offline
I know if that sensor is disconnected your headlamps will be on all the time, same thing probably happens if it goes bad. Should be able to "tap" the dome override button twice to shut them off, if its available on that vehicle it will beep or ding a couple times at you
Old 03-01-2005, 07:52 PM
gvkooy gvkooy is offline
Hey all,
Mark
I have the same problem on a '01. Seems to be an open wire between the body control module and the sensor. The wires at the BCM are white and gray while the wires at the sensor are brown and blue. Problem is, I can't locate where the connection is. My guess is..that's where it's open.
Did you get your problem repaired?
Gvkooy
How to remove headlight LENS on 1999 Grand Marquis LieutenantCracker Grand Marquis 0 01-29-2010 11:53 PM
'90 voyager headlights always on fuzzylink Caravan | Voyager 1 08-09-2006 11:20 AM
Grand Am DRL Headlights always come on no daytime running lights sensor location ? redmachinelover Grand AM 4 12-14-2004 10:21 AM
Headlight "sensor" on DRL equipped models 90LS400Lexus Achieva 1 11-17-2004 01:16 AM
2002 Tahoe Headlight/DRL Problem tonyski C/K 1 04-12-2004 10:29 PM
