Old 01-21-2004, 03:45 PM
95fbird 95fbird is offline
Send a message via AIM to 95fbird
shift knob... does it ever come off?
my shift knob on my 95 bird is not in the best of conditions, so i bought a new knob and went to replace it, but i couldnt get it to unscrew... i know most shift knobs just thread right on i've replaced a bunch of them for my friends, but are they different on the f-bodies? did GM glue them or something?
Old 01-21-2004, 06:40 PM
BlkCamaroSS's Avatar
BlkCamaroSS BlkCamaroSS is offline
Send a message via AIM to BlkCamaroSS
Re: shift knob... does it ever come off?
Nope, not glued, just tightened down. They come off with a little gusto behind it. Lefty Loosey Righty Tighty...
2001 Camaro SS #2239 of 6332
1/4 mile time: 13.575 @ 105.55 mph, 60' time: 2.276
307.1 rwhp, 330.1 rwtq = 353.2 hp, 379.5 lb ft torque
Options: SLP Front Grille w/ SS Center Logo, 17" ZR1 Chrome rims, 6 speed, Hurst Short Throw Shifter, Monsoon 500 Watt Sound System, T-tops, 1LE Performance Suspension
Mods: Holley PS Air Filter, SLP Air Box Lid w/ Mr. Ed's pipe fix, SLP CAI, SLP Bellows, SLP LM, SLP Y-pipe, SLP 160 Thermo, SLP Temp Module, SLP STB, KBDD SFC
Old 01-21-2004, 07:04 PM
Marr-TA Marr-TA is offline
My knob seems to be seperated from the nut that goes on the shift bar. Try sqeezing the shifter knob tight while your turning. Mine would just turn and turn but wouldnt come off.
Old 01-27-2004, 10:55 PM
holov1 holov1 is offline
there should be a thin peice of metal just down in front of the shifter handle.just pry it out and the handle should come off. than thin peice of metal when out looks like a staple
Old 01-29-2004, 01:38 AM
JoeJoe231455 JoeJoe231455 is offline
The procedure gentlemen:
A) Put your parking brake on, and park on a level surface
B)Turn your key forward but do not start the engine
C)With your foot on the brake pedal pull the shifter back to 1, or 2. (Assuming this is auto here)
D)You will see a little clip jammed in at the bottom of the front of the shifter now.
E)Pull it out with needle nose pliers or pop it out with a screwdriver
The shifter comes right off. Secure it down using either screws enclosed or reuse the clip if it can be used.
AC knob does work, but the air is coming only through win and under dinok Lumina 18 06-10-2017 12:58 AM
Slave Cylinder line - How does it come off? Logikal S-10 1 02-09-2005 09:37 PM
Window crank - Does it come off!!! sonsjeep Cherokee 2 04-04-2004 10:18 PM
does anyone know were to get a type r shift knob for a 4th gen prelude. odin4444 Prelude 1 12-25-2001 11:52 PM
does anyone know were to get a type r shift knob for a 4th gen prelude odin4444 Car Audio 3 12-16-2001 02:13 PM
