what in the hell is wrong here???
My car won't go into reverse (Auto). When I start it up it idles at 1.5 rpm then drops down to .5 rpm. When I tap the brakes it will idle higher and if I sit there and pump the brakes a couple of times it will idle all the way back to 1.5 rpms. When I put it in reverse I can hear it idle different I just can't really see it on the rpm gauge. It won't go anywhere in reverse though. Any ideas? Is it a vacume leak? I've been in the market for a a new tranny anyways I just need to know what's wrong 'till then. Thanks.
'92 blue Civic Si -B17a -Carbon fiber intake, full exhaust -Short throw, lowered |
Re: what in the hell is wrong here???
i gotta 5-spd tranny u can have for $75
but u gotta come get itbut to answer ur question.....does sound like vacuum....but since ur car won't go in reverse....seems like ur tranny's going out...mabey
The name's Adrian 1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills 2006 G35 Coupe 6MT - Stock 2011 CR-Z - Stock |
why in the blue hell do you want your car to idle at 1500 rpm's??
Hell I would love to swap it over to a 5-speed but i haven't heard any good stories about doing that. The shifter will go in reverse an I can hit the gas all I want but it won't go anywhere. Oh and there was a weird grinding noise when I tried it a min. ago. I was shifting through the gears and it started to make the noise in reverse but faded away in park, I dunno if that helps but I'm trying to give out more info. thanks.
when you put it in reverse do the reverse lights go on?
Yeah the reverse lights come on, I found out something new, I dunno if this supposed to happen. When I tap the brake pedal there is a clicking sound coming from the gear shift select console thing on the floor. (make any sense?)Thanks.
As far as the gear shifthingy...???...but it sounds $$$ ![]() Jason
hmm, sounds like u blew ur reverse gears apart, not 100% sure but i'd have to be there to know forsure, its always hard to diagnose stuff thru the net, does it still move in forward?? maybe ur not fully in reverse, i dunno,
as for the idle, arent autos supposed 2 idle higher then standards? or is it the other way around?? or am i a dumbass??
94 s-10 bagged, body dropped, 22's, suicide coupe doors, fully shaved, and soon a small block 350 2011 Silverado... Stock Daily driver
yup, my tranny did the exact same thing. I had a blown tranny. Got a JDM D15B auto tranny for $150. Slightly shorter gears and really smooth shifts.
![]() Empty Pockets Racing Member #1 |
Oh...just had a thought...sometimes I have to let my clutch pedal come out ever so slightly to get my shifter to slide into reverse...did this on both my hatch's...just a thought...
Jason
might work.... except he doesnt have a clutch pedal! lol j/phis cars an auto
the noise from your shifter when you press the brake, is the little parking release lever thats lets you shift the car out of park
oh the JDM d15b auto tranny is for 92+ civics only, soooo..if anybody knows where I can get an auto tranny (I can only find 5 speeds)lemme know. thanks.
