Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 01-21-2004, 11:52 AM   #1
4tuna
sunroof seal
Has anyone noticed any leakage in Xterra Sunroof or whistling at high speeds?
I have a 2001 SE and have noticed that when the gear rack is removed, my sunroof seems to make a lot of noise when I get over ~70 mph on the highway. Also was dripping a little (VERY slowly) during a recent major rainstorm.
Has anyone experienced similar issues? What is the solution/fix for this?
Thx
4tuna is offline   Reply With Quote
Old 01-21-2004, 05:29 PM   #2
ChuckH
ChuckH's Avatar
The latch might just be loose. If you remove the little cover on the latch you will see a couple adjustment nuts. Just loosen those (if they aren't already) and pull the latch tighter while the sunroof is open and tighten down the nuts. You don't want to get it too tight or it will be hard to operate and will crush the seal too much, but it should be snug. I had the same problem with air coming through mine and that's all it took to fix it. If that doesn't fix yours then maybe it needs a new seal.
ChuckH
ChuckH is offline   Reply With Quote
sunroof seal valente Grand Prix 5 03-23-2010 01:45 PM
99 olds intrigue sunroof issue!!! smity9089 Intrigue 1 03-22-2009 10:21 PM
Need new sunroof seal. Buckosbeemer 3 Series 0 09-28-2004 10:46 AM
'90 Si sunroof seal DJ Brady Prelude 2 05-18-2004 05:55 PM
Sunroof seal thrasher Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 09-20-2002 01:18 AM
