Old 01-21-2004, 09:37 AM
smcelhe smcelhe is offline
Odometer/gear selection indicator not lighting up
I have a 99 Silverado and the Odometer and gear selection indicator does not always light up. (it works sometimes.)
The odometer is still registering the miles....even when it's not visible.
Any ideas?
Old 01-22-2004, 01:42 PM
Re: Odometer/gear selection indicator not lighting up
Help.........
Old 03-07-2004, 05:48 PM
Lear546 Lear546 is offline
I had the same problem with my 99. The problem seemed the be the re-set switch on the pc board. The display you see gets its power through the re-set switch. I took the entire guage cluster out of the truck and tapped the side of the re-set switch with a screwdriver. The switch is about a quarter inch in diameter. The plunger that you push goes down and hits the switch. After tapping the switch, it illuminated. I took the cluster in the shop and hit the two points where the re-set switch is soldered to the pc board. It has been working fine ever since.
Chevy Astro red gear selection indicator lamp carz_333 M Bodies 1 01-21-2009 05:52 AM
99 Accord - Gear shift indicator dash lights not working after repair sillysimms Accord/TSX/Accord Hybrid 2 12-07-2007 02:08 AM
Digital Odometer / Gear indicator lights flicker ajkolar Problem Diagnosis 0 10-20-2007 11:06 AM
odometer/gear selection light retrohwam Regal 4 10-11-2006 01:47 PM
gear selector indicator not working phuz Blazer 6 05-01-2005 03:56 AM
