Old 01-21-2004, 12:42 AM
shaman5399's Avatar
shaman5399 shaman5399 is offline
Angry Problem with a 68 cuda...
I'm in the process of trying to sell my 68 cuda, and really, the only reason I'm selling it is because the carb crapped out on me a few months ago. Here's what happened...
The fuel tank has rust in it (not a thru and thru hole, mainly surface) it was sending it up the fuel line and plugging my fuel filter every few weeks. All of a sudden, the carb started shooting gas out from the washer that sits over the plunger hole. The only thing I can figure, is that the jets in the carb, (2brrl) got clogged with the rust. How would I go about cleaning it out, or just fixing the problem completely?
Old 01-29-2004, 11:42 PM
vettemaan's Avatar
vettemaan vettemaan is offline
Send a message via ICQ to vettemaan Send a message via AIM to vettemaan
Re: Problem with a 68 cuda...
Get a new carb (4 barrel) and intake manifold from jegs replace the gas tank and fuel filter 500 bucks later you have an awesome Cuda
Old 01-31-2004, 04:11 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Its more likely that rust has clogged the accelerator pump passages or blown the seal on the accelerator pump itself.
Those carbs are easy to rebuild. Either do it yourself with a kit or get a shop to rebuild it for you.
A 4 bbl and intake are a bigger job, but not too much. You did not say what engine the car has. If its a 273 - 318, 4bbl intakes and carbs are as common as fleas on a dog, in wrecking yards, or a new one, which is more money, but less headaches.
If you have a six, just rebuild the carb.
Whatever you do, the tank has to be replaced or boiled out and coated.
Various problems with my 1992 Nissan Sentra XE (4 door) benenarmor Sentra | 200SX (USDM FWD) 0 10-11-2009 11:32 AM
AC System problem with my H22A4 with my P13 crj_lll Prelude 2 01-02-2004 06:54 AM
Problem with brakes with 95 Q45 ahmed_wasim Nissan Cima | Nissan President | Infiniti Q45 0 11-05-2002 02:42 PM
Any known problems with 1997, 528i with 75K ? milindks 5 Series 0 11-03-2002 10:27 AM
What's with it seeming like everyone who buys a body kit has big problems with it? KieR Off-Topic 1 10-21-2002 07:23 AM
