Old 01-20-2004, 11:36 PM
tasha99gs tasha99gs is offline
Send a message via AIM to tasha99gs Send a message via MSN to tasha99gs
strut bars
i need help pickin out a set of strut bars....couple of questions tho...
do i need both front and back or is front sufficient for starters?
what are some good brands to go with? i've found a few diff kinds on the net but they all have diff mounting styles and i dont really know which one would work best and is more dependable and such.........
ive got a 99 GS so if anyone could help me out with at least some info that would be grrreeaaaat!
Old 01-21-2004, 12:51 AM
89Turbo944's Avatar
89Turbo944 89Turbo944 is offline
Re: strut bars
Yes you can go with just a front or rear strut brace if you want. Also have a look at local venders and see what they offer. Most strut bars are very similar.
Old 01-21-2004, 02:22 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: strut bars
Fronts are nearly useless on a 2g. 1) 2Gs dont even use a strut type suspension (in the sense of using the strut as the upper control arm) so there is nothing to brace. 2) the firewall is 6" behind the shock towers, which is a much more effective brace than a piece of 3/4" steel tubing. With all the work I do on my car, I would never use one anyway.
Now a rear brace will be much more beneficial since there is little to no useful bracing in the rear. So I would go rear if you only get one.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-21-2004, 10:13 PM
95 gsxracer, youre my hero.... ....thanx alot
strut bar recommendation dpj52190 Corolla/Matrix/Voltz 1 01-09-2011 10:50 AM
Looking for a Front Upper Strut Tower Bars dd23149006401549 Achieva 1 09-17-2009 05:39 PM
Looking for a Front Upper Strut Tower Bars dd23149006401549 Grand AM 2 09-17-2009 05:31 PM
is a strut bar just a strut bar? toronto pimp '88 - '91 Civic | CRX | Wagon | Shuttlee 36 07-22-2003 10:35 PM
installing Sway Bars/Anti-Roll Bars and Lower Strut Bars..? tsunamiHB Tires and Wheels 5 06-08-2002 04:38 PM
