Hey everyone, I tried to start my car this morning and she started to turn over but then stopped turning the flywheel. I kept trying but all I heard was the starter motor turning like it wasnt engaging the flywheel or something. I plan on putting her up on stands this afternoon after work and pulling the starter out but I wanted to see if anyone had suggestions on what part on the starter it might be so and what to look for and where, if not on the starter, the parts might be located. Thanks, Marty
If you hear a whirring sound when the key is turned to start, but the engine does not turn, the problem is probably the starter 'bendix'. It is located on the starter, and consists of a sprial gear with another gear mounted on the sprial, and a spring. I am fairly sure this is the method of operation (but I am not an expert on the operation) When the starter is used by turning the key, it needs to engage the flywheel to crank the engine. But after the engine starts, it needs to release the flywheel or the flywheel will begin to run the starter and will simply tear it apart from high rpm. (The crankshaft is geared along the outer edge and is quite large compared to the gear on the starter). So, when you hit the key, the starter gear moves along the sprial gear and engages the flywheel (from centrifugal force). Once the engine starts and you release the key, the spring returns the starter gear to it's resting position so the flywheel is not in contact with the starter. It sounds like you could have a broken spring or gear on the starter. Depending on the make of car, the bendix is generally available as a component for the starter. You may want to check the price difference between a bendix and the entire starter, and how much work it would be for you to replace the bendix. Also, if you plan on keeping the car for a while, you may decide that the bendix failure is only the first shoe to drop on a starter going bad. Good luck.
Thanks Philo, I pulled my starter off last night and the gears and the spring looked good so I went to the part store and had them test it. The gear popped out like it should and it spun up like it should. Now I know it wasnt under load but here is some more info on the problem. It does start to turn over and then it just sounds like the motor is turning but not engaging the flywheel. Is there some sort of clutch in the starter that could be slipping? I just hate buying a 150.00 part if that is not the cause of the problem. I know I have some performance problems with the car and I believe its the CAT. Could a blocked CAT cause so much back pressure that it makes the starter not powerfull enough to start the car?
Re: Starter problems
Thanks Philo, I feel enlightened on the inner workings of a starter now. I had someone turn the key for me last night and it does just what you said, it starts to turn the motor as evidenced by the turning fan belts and then 2 or 3 seconds later the belts stop and the starter motor continues to turn so it is being disengaged. And since I'm getting so good and throwing her up on stands and pulling the starter out (which was ther perfect oppurtunity to change that spark plug I could never get to) I will pull it again tonight and just replace it with a new one. The car has 130,000 miles on it so a new starter will be money well spent. I will also cycle the flywheel again to make sure there is no damage to it. Thanks for all your help and I'm sure others will benefit from this post.
It sounds like the bendix gear is giving up the ghost. You can just replace the bendix or the whole starter.
