Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 01-19-2004, 11:32 PM
[JZ] [JZ] is offline
Send a message via AIM to [JZ]
Check Engine Light
I have a 98 tacoma 2.4 and the check engine light comes on after cruising on an open road for a while. I think there is a small crack in the exhaust manifold. Does anyone have the same prob?
Old 01-20-2004, 12:08 AM
wbarrios wbarrios is offline
I have a 98 Tacoma SR5 4x4 Kingcab and got that light "Check Engine" one time. But with that light, the truck suddently started shaking really bad for about a minute or two and it stopped. So what I did, I took the truck back to the Toyota Dealer. They did some diagnostics but they did not find anything wrong and said that it was just a false alarm. Since then, I have not seen that light or felt it shaking that bad. If I remember correctly, that was about 5 months ago since I got that light. Hopefully I won't get that light again.
Old 02-07-2004, 11:16 PM
bamatoyota bamatoyota is offline
I have heard that 02 sensor causing
this on many of the newer toyota tacomas
Old 02-08-2004, 03:14 AM
redtoy92 redtoy92 is offline
Re: Check Engine Light
what is a kingcab???
Old 02-08-2004, 03:16 AM
it could be that or maybe your gas cap isn't holding enough pressure or to much. it can be anything that simple. Next time it comes on take it in and have the DA done and the truck computer will give them a code of what is wrong or what part is causing the problem. do you hear any change in your engine when the light comes on? red
Old 02-11-2004, 11:43 PM
Well it went away for no reason. I was driving in a parking lot and it went away. maybe i hit a speed bump. I don't know, but if I do a DA ill do it myself. Although you need a code reader and a code book i know where to get a OBDII reader for $40 and i am sure its not hard to get a code book. The dealer wants like $100 a shot.
Old 02-12-2004, 08:06 PM
bktaco bktaco is offline
if you have a Palm OS PDA, you can also get a software/hardware solution (google odb ii palm, from 200 - 400 $) that will show codes, run real time parameters, and perform chassis dyno charting. they look pretty sweet, but i dont have it yet.
Old 02-15-2004, 04:00 PM
judgemills68 judgemills68 is offline
The shaking would not come from the gas cap. The dealer had to have read a code. Every time that a code is read on the comp it stores it until it has been manually cleared.
Old 02-16-2004, 02:48 AM
Re: Re: Check Engine Light
I know that! that is why i was talking to JZ! He is the one with the engine light one and doesn't know why? no shaking in his truck
Old 02-18-2004, 06:41 PM
'03DC3.4TRD4X4 '03DC3.4TRD4X4 is offline
Try disconnecting the battery for about 10 minutes to reset the whole system. This has worked for me several times with different modifications I have made that initially "confused" the computer.
Old 02-25-2004, 02:06 PM
also I just recently read that Toyota has had problems with MAF sensors. This will cause the shaking being described. The replacement part is about $150 and less than an hour for install. Also, simply cleaning the sensor has helped in half of the cases.
Old 02-26-2004, 08:02 PM
jasonja jasonja is offline
I just had the same thing happen to me... Dealer found it to be the MAF sensor... I took it out and cleaned it but the light stayed on. Went back and had the dealer clear the code and no more check engine light so I guess cleaning worked.
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
Radio**check engine light controls Impala____Chevy Impala | Impala SS 1 02-20-2010 10:44 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
