Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 01-19-2004, 08:05 PM
4Runner Guy 4Runner Guy is offline
Fuel Filter
I need instructions for the installation of a fule filter in a 96 4Runner. Is there a valve I need to cut off before hand? Is the line pressurized, ect.?
Old 01-22-2004, 10:09 PM
JDW JDW is offline
Re: Fuel Filter
I've got a 92, not sure if it's exactly the same, but is fuel injection - so filter should be similar. No valve to shut off, it is under some pressure so be ready for it to leak when you loosen bolts. Just be sure you don't have any hot trouble lights close by. Be sure to put new washers on when replacing - if it is the banjo type - bolt,washer,gas line, washer-fuel filter. Same on both ends.
It has an in & out - make sure it mount it correctly!
Watch how you take the old one off.
Fuel filter changeout process DennO Ranger | Courier 3 01-02-2011 01:50 PM
2004 Alero Fuel Filter mrchadman Alero 1 02-25-2010 05:38 AM
Fuel Filter Replacement CCMphysician General Discussion 4 01-15-2010 04:27 PM
1982 E-150 Fuel filter HELP Evilfonzie Econoline 2 12-18-2009 11:48 PM
'85 Caprice - More than 1 fuel filter? caffeineaholic Caprice 5 07-12-2009 09:09 PM
