Old 01-19-2004, 07:56 PM
rbmcveigh rbmcveigh is offline
Send a message via AIM to rbmcveigh Send a message via MSN to rbmcveigh Send a message via Yahoo to rbmcveigh
Exclamation Suspension Lift Questions
I am looking into buying a suspension lift for my 95 Chevy K1500 Z71. The lift that I am considering is a 6" suspension lift. My question is, how much of an actual lift can I put on my truck before I have to lengthen the drive shaft? Is 6" too much, or can I get a larger lift? Also, I have tried to think of everything else that will change once I install the lift (i.e. Speedometer needs to be adjusted, brake lines need to be lengthend, gas lines need to be lengthend), but what else will need to be changed? Thanks for your help!
Old 01-20-2004, 12:18 PM
billy2 billy2 is offline
Re: Suspension Lift Questions
Here is the thing... You probably wont need a longer shaft, but it is a slip yolk design and will be at the max outward travel, where as stock it is centered up, or just a little farther in. The kit will use rear blocks, which have the built in degree shims that help angle and driveline length.
You gas lines should be OK, unless your talking about a body lift? The exhaust on that truck has to be modified to clear the front driveshaft also.
Wheels and tires are another big factor! 35x12.50x15 I assume is what the kit is recomended for, Larger tires without a body lift is not possible without cutting some metal.
You may also want to get the matching skid plates for the front to cover up the hole where the front drops down.
And last is a new set of gears. If you run 35's I recomend 4.56 ratio! That is what is in mine and It has all the power like it was stock. I didnt have to change the speedo since I used the gears to offset the tires.
Trailblazer body lift? Suspension lift? 96Z714X4 TrailBlazer | Trailblazer EXT 3 06-12-2005 11:36 AM
body lift vs suspension lift iluvh2o88 Silverado 6 04-11-2005 01:29 PM
body/suspension lift question leandercuasay Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 10-17-2004 12:22 AM
Body Lift or Suspension lift? cbr929pilot Rodeo | Passport | MU 4 08-31-2004 07:23 PM
Suspension lift question RticQl8 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 15 02-25-2002 10:58 AM
