Old 04-10-2005, 10:46 PM
iluvh2o88 iluvh2o88 is offline
body lift vs suspension lift
whats the difference between a body lift and a suspension lift?? and which is better??
Old 04-10-2005, 10:57 PM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
Re: body lift vs suspension lift
a body lift just lifts the body and a suspension lift lifts up the whole truck. with a body life you get no extra clearance and IMO it looks stupid. A suspention lift is functional.
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 04-10-2005, 11:58 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: Re: body lift vs suspension lift
Agreed. The only thing you gain with a body lift is clearance for bigger tires and a higher center of gravity (). Think of it in terms of an exhaust system: True dual exaust is more functional, but costs more than a cheap split single. Both give the same basic "look," but the cheap way does not function like the better, right way to have dual exhaust. You can liken a body lift to a cheap "splitting" of a single exhaust, and a suspension lift to a more expensive, more functional true dual system.
Old 04-11-2005, 12:04 AM
korndogg's Avatar
thing i hate bout body lifts is that you can see the frame...
1968 Camaro 327
{o,o}
|)__)
O RLY?
Old 04-11-2005, 06:37 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
I agree wiht all of the above. Body Lifts are crap In my opinion.... Suspension is the way to go..even though it might cost $1000 more.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-11-2005, 10:00 AM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
I agree with all.
*Under Construction - New sig to debut*
Old 04-11-2005, 01:29 PM
Moose is loose Moose is loose is offline
A body lift does not raise your COG nearly as much as a susp. lift does. If your goal is bigger tires, go with the Body. If you want extra travel, well, your pretty much screwed with an IFS truck. The torsion bars must be lowered the same height you lift the truck. Look at a lifted IFS truck, the T-Bars hang way down beneath. The only real ground clearance you achieve is the front diff, and really from larger diameter tires. If you want ground clearance, buy a Super Duty or Ram, and lift that.
