Go Back   Automotive Forums Car Chat > Hyundai > Excel
Old 01-19-2004, 06:37 PM
sgirl71 sgirl71 is offline
Question Urgent Help Needed - Hyundai Excel 98 Model
Could someone help me urgently - I need to find out how to get the drivers side inside door panel off to fit a new lock barrel on my 98 excel mainly the window winder - anybody please help
Old 01-19-2004, 06:38 PM
Re: Urgent Help Needed - Hyundai Excel 98 Model
Removing window winder on 98 excel - help urgent
Old 01-19-2004, 08:50 PM
tibby01 tibby01 is offline
www.hmaservice.com/webtech
Old 01-19-2004, 09:09 PM
tibby01 - where do I find the information on that site
Old 10-07-2004, 01:49 AM
excels_rock excels_rock is offline
can someone tell me where i can buy a cheap but good looking body kit for my 1996 excel???
Old 10-24-2004, 11:47 PM
binnsy2004 binnsy2004 is offline
Thumbs up how to pull off door trims
Hey, dunno if you still need help or not but here goes anyway;
you will need
a little hook, i use a bent coat hanger, this is the best tool ive found
a phillips head driver
mother f$#%ing patience cos the #$%@ing things are studpid
first undo all the screws you can see, i think there are about 5; two inside the part of the door covered by the dash, and the two in the arm rest, and one in the door handle
next use your little hook to pull of the locking pin behind the window winder, you may need to push down on the arm of the winder to expose the back. (note: The pin looks very similar to the omega symbol in the greek alphabet) All you need to do is hook it, and pull hard. This will almost make the handle fall off, if not just yank it off.
Next, and this is the dumber part pull pull at the door trims till the little plastic clips pop out and the trim is loose, but dont take it away yet, you need to move the door handle fitting forward to unlach it, then slide it back throught the hole in the trim (i broke mine not realising it had a latch)
viola theyre off
good luck understanding these instructions...
Binnsy
Urgent Help Needed w/ Arms Ridenour COMPLETELY off-topic 15 03-21-2005 08:34 AM
Urgent Help Needed Dov Alfasud 1 12-28-2004 10:34 AM
Urgent help needed Savage Messiah Camaro Discussions 9 07-16-2004 01:05 PM
Urgent Help Needed hondaokie Accord/TSX/Accord Hybrid 4 06-30-2004 12:13 PM
Urgent help needed with injector problem ci5ic Cherokee 4 06-07-2004 08:56 PM
