Old 09-17-2004, 08:47 AM
budzy0844 budzy0844 is offline
Heat and AC not blowing out
Why would the heat and ac not be blowing out
Old 09-17-2004, 03:37 PM
matt919's Avatar
matt919 matt919 is offline
Send a message via AIM to matt919
Re: Heat and AC not blowing out
last week, mine stopped blowing out as well. I assumed i needed to replace the blower motor, but before i got a chance to do that.. it started working 3 days later. So, maybe it will just kick back in for you as well? if not, probably the blower motor.. if it doesn't work on any setting..
Old 10-12-2004, 06:35 AM
kazy_48098 kazy_48098 is offline
Does it not work at all? Or does it work in one of the settings? You may want to buy blower motor resistor. It is like $20 and simple to change. My blower only worked in the highest setting. Soon as I changed resistor, works great.
Old 10-12-2004, 12:01 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
the blower resistors are a common problem on these cars. Try putting direct power to the motor, if it kicks on, it's the resistor, if not it's the motor
Old 10-12-2004, 01:43 PM
kevin_W's Avatar
kevin_W kevin_W is offline
Mine had a problem with the air flow.
The motor was working, heater core was great, but no air flowing through the system. The problem was dirt and crap not allowing air to flow through the firewall. Once the motor was out, I looked down the hole and had to clean that out. Now I have fantastic air flow.
Good luck
