What to you think she will run???
I Have A 91 Crx Hf Converted To Si. What Do You Guys Think It Will Run This Spring At The Track? I Race At Pacific Raceways In Kent ,washington With A Nova ,but This Year I Want To Run The Crx For Fun Too. Here A List Of What Ive Done To It.
91 Crx Hf Gutted W/2 Seats And Dash Etc..door Panels No Carpet D15b6 With Zc Sohc Head Zc Sohc Intake Manifold And Inject. Ported Polished And Milled 10.0 To 1 Est.compression [hf Block Has 9.6 To 1 Compression And With The Head Milled ] Holley Fuel Regulator Runnin Race Gas 108 Octane Msd 6 Al Ignition With Accel 8.8 Wires Custom Air Intake Dc Header ,flow Master Exh. Pm6 Ecu With Chip , 9000 Redline Hs Coilover Kit With Integra Gsr 15 In Wheels WITH MT SLICKS ON FR Stock Tranny [si Tranny Soon] Hf Suck Ass A.c.t Stage 2 Clutch Soon To Come Zex Dry Nitrous System!!!! Days I Hope One Off Traction Control Device . Fabbed It Myself@ My Shop I Think Thats It For Mods, Basically Car Is Sound And True Beside Trying To Do This With A Wierd Combo Like This Is Different. I Hope To See At Least Low 15's Maybe Even 14's Out Of This Setup .ive Raced A Nova For Years And Its Fast [10.20@130's]with My Dad As A Team. But All My Buudys Are Into Hondas As So Im I Too. So I Just Wanted Some Guestimates On What This Setup Will Do?what Should I Chhange Or Improve?any Other Mod Hints Will Be Great!! Thanks For Your Time To Read All This. Thanks!!! |
probably the 1/4 mile....
2000 BMW 323IT 1954 Ford F100 With every post my penis grows smaller Yakima Valley Truck Club Yakima Washington |
Re: What to you think she will run???
1 horsepower = moving 550lbs 1ft per second - if you know the weight & HP you can calculate any 1/4 or 1/8 mile time.
108 octane is a waste |
it also depends on how well you drive it
I just noticed that you're in Kent, I'm going up there thursday to pick up a car. Imagine that....
108 octane...lmao there goes your fuel injecters and maybe fuel rail plan on keeping those stock..have fun...108 octane on that worthless, wont help but give you a tow truck at the end of the track
Re: Re: What to you think she will run???
to high of octane melt you injecters......
Location: Logan Utah Black 1990 CRX Si FI d16a6 R.I.P 1995 DC Integra LS jdmb18b w/ ys1 trans SOLD 1990 EF civic Si sohc ninja project Traded 1992 EG vx hatch sohc turbo/gsr swapped SOLD 1992 DA9 obd1 love, non-vtec love project |
As American As A Burrito! USDM 4 life! |
Re: Re: Re: What to you think she will run???
108 octane is for HIGH compression engines, not practically stock 4 bangers w/ 10.0:1. The fuel wont get burnt properly, therefore its useless - it does smell good. You could run 90% nitro meth. & 10% methanol, it still aint gonna make your car any faster.
My cylinder head is worked - milled, p/p, 3angle - along with other work & it runs perfectly fine on 89 octane. |
If he wants to spend his money on high octane then let him, but it's not going to hurt anything... and definetly won't "melt" his injectors
![]() That HF tranny is going to be your limiting factor IMO, you'll be coming through the traps in 2nd gear most likely around the high 15/low 16 mark probably.
1991 CRX SI (black) 15.3 @ 88mph (stock motor) '90 B18A1 swap Custom exhaust *2.25" piping *two glasspacks (inline) *polished flash-cut tip *exits pass. side, front of rear tire. '95 GSR 15" wheels 195/50/R15 Bridgestone Potenza SO-3's AE Eng. front crossmember Susp. Tech. 22mm rear sway bar Susp. Tech. 1.8" lowering springs Tokico Illumina 5-way adj. shocks Powerslot rotors Metal Master pads Goodridge steel-braided brake lines Red painted OEM calipers Skunk2 short shifter Skunk2 shift knob GT Grant steering wheel Red/black racing seats |
melt the injectors.. rofl
