Old 01-18-2004, 06:54 PM
monte74 monte74 is offline
Torque converter wont go back on
I'm faced with a perplexing problem. Got a 91 RS with the 3.1 and I sent the engine and with the torque converter still attached out to get rebuilt.
It all comes back with the torque converter off the engine, I get all parts back on the block ready to install. Grab the converter push it on the spindle and it won't slip all the way back and engauge the pump. It sticks about 1 inch after I slip it on. Tried tapping it farther with a hammer and it only moves it another few 8ths of an inch. Pull it back off and I find halfway down the larger spline on the shaft little groove marks like it has jambed itself down to that point.
I am perplexed. I have never had this happen before on all the trannies I've worked on. They usually just slipped right on and with a little wiggling they finally seat all the way back.
I am checking with the machine shop to see if I got the wrong coverter back by mistake but I doubt it.
Have any of you ever run into this? If so what avenue did you take? I sure dont want to rebuild the tranny or buy a new converter.
Thanks ahead of time.
Old 01-18-2004, 10:00 PM
hot_red_z28 hot_red_z28 is offline
Send a message via ICQ to hot_red_z28 Send a message via AIM to hot_red_z28
Re: Torque converter wont go back on
I sure hope didn't fug it up by hitting it with a hammer. That is a big no no...
Did you rotate it while applying pressure. You should be able to put it on until it goes in one level, then you have to rotate it slightly (i believe in the clockwise direction) while applying a little pressure and it should pop down a little farther, and I think you might have to do that one more time to get it fully seated on the input shaft.
If you've tried that and still don't have any luck, I'm not sure what to tell ya...
My Project Write-Up
Old 01-18-2004, 10:51 PM
caw333 caw333 is offline
Yes a hammer is a big no no in the torque converter world. So please don't go looking for a bigger hammer. Your torque converter should go on the shaft 3 different times simply by sliding it on till it stops then rotate applying some pressure and when it slides on again then rotate again applying pressure and it should slip on again.
Old 01-18-2004, 10:57 PM
Oh and one more thing. If the converter isn't on all the way on the shaft and you bolt the trans up to the motor and try and crank it say bye bye to the front pump and the 90 to 100 dollars its going to take to replace it. Good luck.
Old 01-19-2004, 12:44 AM
1992RS 1992RS is offline
Send a message via Yahoo to 1992RS
I take it you've done this before caw333??
Old 01-19-2004, 12:55 AM
It was just a few taps with a small hammer. Just to see if it was snagged. But before that I did the whole wiggle turn push almost 50 times before that.
Just a bit puzzled.
Old 01-19-2004, 05:38 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Just keep on turning and applying pressure..... It took forever when I got my torque converter. Hope the hammer did'nt do anything.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 01-19-2004, 05:41 PM
comp comp is offline
some are a pain in the azz, did you pour a qt. of fluid in con.vert. first?
check for a small burr, just don't loose your cool
Old 01-19-2004, 09:43 PM
Well......... 1992RS I never tried the hammer trick but what I did do was bolt the torque converter to the flexplate and tried to stab the trans on to it while the motor was out thinking I could turn the trans enough to get it to seat properly. Please note that this also is a very bad idea. Always put the converter onto the trans first and then bolt to the flexplate.
Old 01-19-2004, 11:37 PM
Well I ended up fiddling with it for hours. Finally pulled the trans and am sending it to some one smarter than me. Hopefully it won't be too painfully costly.
Thx for the help.
Old 01-21-2004, 01:12 AM
It seems in removing the engine with the TC attached due to a seized engine, the TC was fugged up inside plus a seal on the tranny input shaft. I gotta get out of this hobby. It only costs money.
Old 01-21-2004, 02:22 AM
What?? Get out of this hobby!! Now your talking crazy. Just take a couple of deep breaths. So what if you have to eat Ramon noodles for the next month its worth it.
Old 01-21-2004, 05:20 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
well said caw333
Old 01-24-2004, 11:31 PM
Well it seems when we separated the engine with the torque converter still attached to the fly wheel (Engine was seized) it bent the TC nose enough that it was out of round and would not fit back on the shaft. Long story short, $80 TC. Oh well. It's runnin now. Just have to track down why the Fan is not kicking on.
Old 01-24-2004, 11:42 PM
Vlad_Tepes's Avatar
Vlad_Tepes Vlad_Tepes is offline
Check the fuse bro then if thats not it check the wiring might have gotten "pinched" somewhere
Yeah yeah I know it looks like grandpa's but wait til I put the LT1 in it
Squealing torque converter Skitzy Express | G Van 4 04-05-2010 02:09 PM
05 tahoe torque converter out. . ??? help bcmagg Tahoe 8 03-22-2010 12:32 PM
torque converter wont disengage 1995rivierguy Ram Pickup | Ram SRT10 4 07-29-2008 02:41 PM
95 torque convert wont seperate from flywheel 4x4playhus Montero/Shogun/Pajero 4 03-13-2007 07:20 PM
1988 Z24 Transmission problem, torque converter wont lock after transmission change Dale24 Cavalier 4 01-23-2004 03:29 PM
