Old 01-18-2004, 04:48 PM
swollen swollen is offline
Shaving down tires.
I would like to shave down a set of solid tires that I have. I'm trying to get the car lower and the tires are hitting the tops of the inner fender.
any help would be great.
Mike.
HI! I'm your friendly nieghbourhood Mike.
Just so you know, giant pictures in your signiture make the baby Jesus cry
VW Vortex.com
VW Drivers of Vancouver
Mine = 1990 VW Jetta Xflow ...all go, no show.
Hers = 2000 Pontiac Sunfire... I know, i know
Old 01-18-2004, 04:58 PM
Jay! Jay! is offline
Horizontally Opposed
Re: Shaving down tires.
In 1/24 scale, right?
If you can, mount the wheel/tire in your drill and lightly apply pressure w/ a sanding stick. Use a low speed, and only do it in short bursts as to not build up too much heat...
That's what I'd do, anyhow...
Hierarchy of Subaru:
(Click to see mine!)
Old 01-18-2004, 05:04 PM
phatmitsu's Avatar
phatmitsu phatmitsu is offline
Send a message via AIM to phatmitsu
Put some smaller tires on it.. JK
I dont think there really is a good way to get the tires smaller(lower profile) You could chuck them up in a drill and sand the hell out of them but then you got no detail tread wise.. I would suggest trying a few of the following.. Well depends on what your building..
Slammer model(no chassis detail just slammed to the ground)Cut out everything that stands in the way of the tire then if still not low enough Ive seen people cut the tops of the tire completly off.
If your doing a full detail model cut out the wheel wells to get it lower. You can also just grind the wheel well to make it a big bigger.
Trying the options above should get jsut about anything down to the ground.. UNless your teying to stuff some monster tires in a tiny car.. If ya need more help aim me at phatmitsu69 or even let me know what your building and ill try and help ya see if we can get it lower..
Never argue with an idiot. They drag you down to their level then beat you with experience.
Old 01-18-2004, 05:25 PM
Its a 67 Bug convertable.
There are no inner fenders to shave or remove and just cutting out the top of the tire will look goofy.
Its quite common for the old aircooled guys to run temporary spare tires to get the cars lower to the ground.
VW Vortex.com
Old 01-18-2004, 05:32 PM
phatmitsu's Avatar
Yea in a bug there a little diff to get down.. Id try what Jay said but then you lose tread detail. Only other thing to try would be low pro tires.. Good luck on it.. Get some pics for us to see.. Later Rick S.
Old 01-18-2004, 05:48 PM
Zcaithaca's Avatar
Zcaithaca Zcaithaca is offline
fershizzle
Send a message via AIM to Zcaithaca
...its a 67 bug....after 37 years the tires will be worn...i would do whay jay sugested...he knows his stuff
Zach
Old 01-18-2004, 07:24 PM
86_SR5's Avatar
86_SR5 86_SR5 is offline
Re: Re: Shaving down tires.
Ya know, I've had that same problem. I tried with some sanding drums, sanding the inside of the tire, well to fit a bigger rim. never got too good with it. I think you should just sand your tires down, and if they're flat enough, you can call them slicks?
RIP Indian Larry RIP
April 28th, 1949 - August 30th 2004
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 01-18-2004, 07:55 PM
Thanks for the help guys.
VW Vortex.com
Old 01-18-2004, 09:41 PM
Let us know how it works out...
Winter tires - speed rating & downsizing Hello: A couple of questions for the forum. I have an 07 Camry LE. I am buying winter tires for her. I am jtmann Tires and Wheels 3 11-18-2010 09:07 AM
gas mileage decreased with new tires?? Dolphingrrl23 General Discussion 5 08-21-2009 04:01 AM
trunk pull down closer ksflatfoot General Discussion 0 03-20-2009 08:43 AM
Tire pressure. sailor86 Engineering/ Technical 26 03-18-2009 04:44 PM
Shaving down tires??? Hash_man Car Modeling 15 08-04-2002 10:30 PM
