Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 01-18-2004, 04:45 PM
StephenR StephenR is offline
Send a message via AIM to StephenR
Crankshaft position sensor???
92 dakota 3.9L
On cold starts my idle dies out then comes back over and over. after it warms up it does fine but has a lack of power. mechanic said it was the CSPS (subject.) costly reapair, want to make sure. any ideas?
Old 01-18-2004, 07:39 PM
rodkahle rodkahle is offline
I had a similar problem with my '92 Dakota V6, but mine was due to corrosion in the ignition system. Check your spark plug wires, distributor cap, and rotor for corrosion. If you need to replace the distributor cap and rotor, I would suggest you get copper instead of aluminum. I had aluminum parts but the salt air / fog here by Savannah really corroded everything so bad, it was very hard to start.
Also check or replace your ignition coil. Good luck!
Old 01-18-2004, 07:53 PM
dano 360's Avatar
dano 360 dano 360 is offline
Re: Crankshaft position sensor???
I would also try doing a tune up first and go from there. I found CSPS for your truck for $89 and $76 here http://www.trademotion.com/partlocat...?siteid=213794 not too expensive. If it mounts anything like the one on my truck it's only 2 bolts. Its a bitch to get at but you dont have to remove anything. not a very big job.
Danny
01'RAM 1500 QC 4X4 5.9, 00' Mopar PCM,52mm Fastman T/B, K/NGen 2, Flow Tech Headers, Magnaflow Exhaust, Accell Cap Rotor, MSD Ignition-8.5mmWires,180*TStat, SkyJacker Hydros & Dual Stabilizers, 2"Daystars, Westin Nerf Bars, D/T-Trac Bar, Eagle Alloy 184's
04' GMC Sierra 1500 QC Z71 Off Road 5.3
99' Durango SLT 4x4
Old 01-24-2004, 04:39 PM
I had the CSPS changed but there is still no difference. My buddy said it may be the "hall efects switch" at least that is what I think he is saying. he said it is under the distributor. let me know what yall think please.
Old 02-23-2004, 12:57 AM
amac209 amac209 is offline
Send a message via MSN to amac209
get a good shop to check all the sensors with a scan tool and do a tune up(plugs, cap&rotor, air&fuel filters). it gets expensive when you start throwing parts at a problem. i suggest taking a look at the intake and iac(idle air controller) these are prone to gumming up on dodges. i saw one where the iac was completely clogged with carbon. get some carb cleaner and a toothbrush and get scrubbing!!! good luck
Old 03-08-2004, 09:57 PM
nightdriver09 nightdriver09 is offline
What are your codes?? You should have some at least stored if not thrown. And the crank position sensor is not that much, plus it's not hard to do. You say it dies at idle, but then doesn't have power after warming up? That could be something other than sensors. But there is another thread we
have had going for a month. He just said his prob-
is solved. Guess what? CTS and CTS switch. As to the IAC motor, I suggest www.intensedakota.com before doing that. It's tricky, and he has very good
instructions posted for how to do it correctly. If I had to guess, I'd say it would only be a small part of your problem.
Crankshaft position sensor GregGP Grand Prix 1 03-25-2010 04:33 PM
Pontiac GA Cam position sensor LOCATION ? cigars99 Grand AM 6 07-11-2009 10:30 AM
Crankshaft Position Sensor Mykle57 Cherokee 1 10-13-2003 04:08 AM
Crankshaft position sensor ECU code 4 viba '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 05-04-2003 04:30 PM
Crankshaft Position sensor (reference)? 95MAXIMASExy Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 03-18-2002 02:33 PM
