Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 03-17-2002, 09:12 PM
95MAXIMASExy 95MAXIMASExy is offline
Send a message via AIM to 95MAXIMASExy Send a message via Yahoo to 95MAXIMASExy
Crankshaft Position sensor (reference)?
When I checked my code in the self diagnostic it gave me this, what exactly does this mean, how can i fix it?
Old 03-18-2002, 02:33 PM
Ravq Ravq is offline
There are two engine sensors with similar names and similar functions.
# 1) Crankshaft Position Sensor (POS).
This sensor is located on the oil pan facing the gear teeth (cogs) of the signal plate (flywheel). It detects the crankshaft position signal (1 degree signal). A malfunction of this sensor may set the Diagnostic Trouble Code 0802.
#2) Crankshaft Position Sensor (REF).
This sensor is located on the oil pan (upper) facing the crankshaft pulley. It detects the TDC (Top Dead Center) signal (120 degree signal). A malfunction of this sensor may set the Diagnostic Trouble Code 0407.
There is a procedure to check the sensor using a multimeter or voltmeter but I suggest you get a repair manual to do so.
Stillen kit & grill, Stillen Type II spoiler, KYB AGX/Progress, 19x8.5 ADRs w/Toyo Proxes FZ4s, ...........
