Old 01-17-2004, 07:33 PM
vpap1's Avatar
vpap1 vpap1 is offline
Pontiac 400 pistons and cam
I have a 78 pontiac 400 out of a trans am.
I just finished tearing it down and was looking for possible part ideas.
I looks like it had less than 60k on the motor i might be able to get away with a std bore.
Anyways, i'm gonna keep the stock crank and rods, if still good ofcourse.
I really want flat topped pistions, for the increase in compression, does anyone know where ican find of buy flat tops for my pontiac??????
And I currently have a set of 6x heads, i am going to have 1.77 exhaust valves in place of the 1.66's and mill them a touch.
Next i'm looking for a cam about 280 degrees of druation at .050 and maybe .490 life will 1.6 to 1.65 rockers. Any specific parts anyone had great luck with??????
thanks
Old 01-18-2004, 02:43 AM
petereggy petereggy is offline
umm are you sure about 280 degrees at .050???? thats fuckin huge man
as for pistons speed pro's powerforged is a good piston but they only make in +.030 for 35 bucks us
Old 01-18-2004, 10:06 AM
vpap1's Avatar
Re: Pontiac 400 pistons and cam
yeah i meant 280 adv duration about 230 at .050
thanks for the piston tip!
Old 01-18-2004, 06:48 PM
yah I figured that but I didnt know if you were planning on some insane drag motor or something...
umm check out comps xtreme line they seem to have pretty decent cams
Old 01-18-2004, 07:30 PM
vpap1's Avatar
Yeah i want this thing to be steetable for the most part but i want it to be kinda wild street, 450 hp +. On pump gas, 9.75 to 10 compression. But i'll look at comp to see what they got
Old 01-18-2004, 07:37 PM
vpap1's Avatar
Yeah comp cams has a nice cam for my project, an extreme energy cam like you said with 230 236 duration at .050 and .488 .491 lift with higher ratio rockers= perfect ans with 110 lobe separation, thanks anyother tips??????
Old 01-18-2004, 08:35 PM
umm I had a whole 400 setup worked out that would have made that kind of power
a set of hedman 1 5/8's primarys are good
get some head work done like a 3 angle valve job some porting like 250 and 230 or so
torker 2 intake is good if not use preformer rpm
thats about all I got for now
Old 01-19-2004, 06:54 PM
vpap1's Avatar
Thanks for all the help.
I appreciate it.
Old 01-19-2004, 08:36 PM
no prob by the way the 2 numbers for the head work are intake flow rate at .600 for the first one and exhaust at .600 for the second
Pontiac 400 Forged pistons Brand New 79Bandit Cars/Parts for Sale/Exchange 0 02-13-2007 11:41 PM
pistons, valves and cam TAKE A TOKE General Discussion 1 01-21-2006 04:32 PM
351m with 400 Camshaft and Pistons ThroughMyShadow Engineering/ Technical 2 08-22-2005 01:07 PM
Need Help....Pistons, Rings and Cam for 2.5L ELESWON S-10 1 07-08-2004 05:25 PM
