Old 01-17-2004, 06:47 PM
Bremln Bremln is offline
93 Suburban dies when running idle and is hard to start
My suburban will not run when idle. It occasionally starts and will run for a little bit, but then cuts off. I have checked the sensors, and they all seem to be in good shape. The fuel pump cuts on when I turn the key, and I can hear fuel getting to the back of the throttle body. I have replaced the fuel filter, but that didn't fix the problem. The injectors appear to be getting the signal to fire because when hooked up to a multimeter, I get 12V running through. Could the problem be with the fuel pressure regulator or is it electrical? Any other suggestions for tests I could run? Thanks, Brett
Old 01-17-2004, 07:29 PM
Dr. Eagle Dr. Eagle is offline
Re: 93 Suburban dies when running idle and is hard to start
How does the spark look???
IS there any? Cap rotor look OK, plug wires, plugs all in good condition?
Old 01-17-2004, 08:10 PM
Tat2dBrownDude's Avatar
Tat2dBrownDude Tat2dBrownDude is offline
Check spark at plugs (use plug wire pliers so you dont get zapped). Check fuel pressure using a gage, it should be at 42. Have you scanned it yet? See if there are any codes coming up, post it here and maybe I can help.
"The Anti-JEEP"
Old 01-17-2004, 08:23 PM
Good idea to check fuel pressure, I'm still thinking spark on first pass. If it is not, and fuel pressure is good, could be TB injectors. I did end up replacing mine at around 100K as I recall and it had similar symptoms.
Oh yeah, and in addition to my Suburban, I also have TWO jeeps... ....nice....
Nothing but SUVs here at the Eagle Roost.
Old 01-18-2004, 08:50 AM
Yeah, it could be the TB injectors also. Good call.
I have a 99 Cherokee, but it is the family vehicle, so it is done mildly. It has a Rusty's 4.5 lift and some 33's with beadlocks. My wife wont let me trail it though, because it is hers.
"The Anti-JEEP"
Old 01-18-2004, 11:43 AM
The next step I plan on trying is looking at the fuel pressure and trouble codes. I have a gauge but it doesn't seem to work correctly. It's kind of old. A new one is about $40 at Sears. I'm pretty sure it's getting spark because the plugs were replaced not too long ago, but I'll check that if the other tests turn out ok. I think I forgot to mention that when I try to crank the engine fuel only comes out of the injectors once every third try or so. That's why I'm thinking it's something wrong with the fuel and not the spark. Thanks, Brett
Old 01-18-2004, 02:48 PM
OK now that you mention that info, I think you are right. Now I am betting on the injectors...
Old 01-18-2004, 02:52 PM
Re: Re: 93 Suburban dies when running idle and is hard to start
Yeah, I have a 00 Wrangler Sahara with a 4-1/2" Lift 33" x12.5 tires...nothing radical...just nice looking. I have had it up to the Rubicon, but it is not really set up to rock crawl.
The wifes car is an 00 Grand Cherokee with the V-8. I have done nothing but Rancho shocks on it, and she hates them. She is not so into the boy toy thing....
Old 01-19-2004, 12:23 AM
Well, I bought an Acton III fuel pressure tester today, so as soon as it warms up a little, I'll check the fuel pressure and let you guys know what's up. In the mean time I guess I can go ahead and check the trouble codes. More tomorrow... Brett
Old 01-19-2004, 12:28 AM
Oh yeah! Has any one every heard of a NOID kit and where I might be able to find one? It's basically something you plug in series with your fuel injectors, and it lights up when an electric pulse goes through.
Old 01-19-2004, 12:43 AM
Give this a try:
NOID
Better still:
Northern Noid
Old 01-20-2004, 10:26 PM
OK, so I finally have an update on the situation. No trouble codes are appearing, and the fuel pressure is a constant 13 psi while the engine cranks or is running. If the suburban starts it will continue to run as long as the rpms are kept above 1000. I plan on ordering a NOID kit sometime soon to see if the injectors are getting the signal to fire. This is getting pretty crazy. More to come soon... Brett
Old 01-23-2004, 06:48 PM
Well, I got the NOID kit at O'reilly's auto parts and put it on the burb. When I cranked the engine, it didn't light up, indicating that no signal is getting to the injectors. By chance, it started up, and as I kept it above 100 rpms, the light was on, but when I took my foot off the accelerator, it died and the light went off. So now what should I do?
Old 01-25-2004, 03:28 PM
Ahhhhh!!!! This is driving me crazy! The wiring harness, injector solenoids, fuses, relays, you name it all appear to be in working condition. Why isn't this thing working? I am almost convinced the ECM is bad, but no trouble codes appear. Does anyone know why an ECM would fail to give the injectors a signal to fire when cranking or running idle and provide a signal to the injectors when I keep the rpms up? Is it failing? Please, any help would be greatly appreciated! Brett
Old 03-08-2004, 02:10 AM
arejones arejones is offline
Did you find out what the problem was with your burb. I'm having similar problems.
hard starting dieseltrucktech Cavalier Problem Diagnosis 3 11-08-2010 01:17 PM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 08:52 PM
Rough idling and hard starts ksubenny Problem Diagnosis 5 04-07-2008 01:22 AM
Fixed My rough idle and hard start problem LELeach Grand Cherokee | Grand Cherokee SRT8 2 12-09-2005 01:00 PM
Thumping sound when I turn and hard start twodmm Integra 2 06-30-2004 09:57 AM
