Old 01-17-2004, 04:45 PM
wocottchief wocottchief is offline
Unhappy 2000 silverado 5.3 liter Z71 cylinder 2 & 7 misfire
Any ideas?
70,000 miles on truck. Cylinders 2 and 7 misfire. I have changed all the spark plugs, all the wires, put in new coils for 2 and 7, changed fuel filter, and replaced vacuum solenoid on gas tank with modification kit. The fuel pump has good preasure. Cylinders continue to misfire.
Any suggestions or ideas appreciated.
Thanks,
Jeff
Old 01-19-2004, 08:37 PM
dogdrake dogdrake is offline
Re: 2000 silverado 5.3 liter Z71 cylinder 2 & 7 misfire
try swapping the injectors and or coils wires to another cyl. to see if the mis moves . sounds like the injectors.
Old 01-20-2004, 07:12 PM
Thanks dog...already gave in and took it to the dealership....ahhh o'well.
Jeff
Old 01-20-2004, 10:02 PM
Bill-SILV Bill-SILV is offline
Can you tell what the dealership tells you? I have somewhat the same proble also but my said multiple cylinder misfiring. Plus I think this goes along with my other problem on this link.
http://www.automotiveforums.com/vbul...d.php?t=177017
Thanks
Old 01-21-2004, 07:52 PM
Bill...i'm not sure you really want to here this but here it goes...
the dealership called today..first they wanted to run a high preasure cleaner through the fuel injection system...i said sure go ahead ($110.00)..the dealership called back 20 minutes later and said..."umm..now we have clogged up the whole sytem and made it worse..we think that the fuel rail is plugged ... so we want to replace the fuel rails, preasure regulator, all the injector, the vacuum solinode (that i changed four days ago!), and drop the gas tank to clean it out." Now they are basically replacing the entire fuel injection system from the gas tank all the way up. FOR A MEAR $2,100.00!!!!! They THINK this is probably gonna fix it.
Seeing that the truck is three years old (i bought it new in january 2001) I don't have alot of choice in the matter.
I hope you don't have this same problem ..(if it helps my gas tank censor has also been bad for the last year..i'm not sure if its related to the same build up..but maybe.)
I'll post to let you know if this resolved the problem.
A trade in may be order in my near future.
some advice...if you or someone you know have the skills..buy the 500.00 in parts...and try this procedure yourself...you may even be able to recycle some of the parts after machine wash out..dealerships won't do this.
jeff
Old 01-23-2004, 09:25 PM
Dealership fixed it..as described above.
Jeff
Old 01-23-2004, 09:30 PM
Did they replace all that stuff and now its fixed? Because Im thinkin on mine I had the injectors cleaned on mine so that leaves the fuel rails, pressure regulator, and vaccum solenoid. Where is the vaccum solenoid you were talkin about and is there a way to see if its bad?
2000 Silverado 5.3 Piston slap. Rebuild? or replace FNAndy Silverado 7 09-10-2010 05:23 PM
2000 Silverado 5.3L 1500 4x4 Silverado_Dude Silverado 21 11-24-2009 10:02 PM
2000 Silverado 5.3 hard to start. ColoradoSilverado Silverado 17 07-22-2009 08:50 PM
2000 Silverado 5.3 Hesitation on acceleration jphelps1976 Silverado 13 01-11-2009 04:34 PM
2000 silverado 5.3 o2 sensor help derbymanigp2 Silverado 1 04-18-2008 07:28 PM
