Old 01-16-2004, 09:19 PM
91GSX92Mustang 91GSX92Mustang is offline
Need help Converting Automatic Into Manual
I need help tracking down a kit that I need to change a Automatic to Manual Trans. IF no one knows of a place that has this kit please provide me with all the help u guys can give and help me piece it together.
1991 GSX Eclipse
So far I know some of what I need please fill in where i am missing parts:
Clutch Pedal
Clutch Cable and/or
Master/Slave Cylinder
Manual Trans of Course
Flywheel
Clutch
Shift Kit
Thats all I can Think of that I need off the top of my head. Please help me fill in whatever else I need unless you can provide me with a company that has a kit. Thanks and all the help u can give is Very appreciated.
Old 01-16-2004, 09:26 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
from what i have heard its a pain in the ass but www.VFAQ.com has a step by step guide for the 1st get eclipse/talon under tranny... it also has a list of the parts you need, i'd suggest looking there! good luck
Old 01-16-2004, 09:28 PM
Thx alot i'll check it out and if anyone else has a suggestion of a site or a kit someone might have let me know, thx.
Old 01-16-2004, 09:37 PM
Bronco2 Bronco2 is offline
Re: Need help Converting Automatic Into Manual
Not a Mitsu expert,but you may want to call the local junkyards and buy a wrecked car with no motor .The small pieces you need for this swap will drive you nuts unless you have a parts car to pull them from.
Old 01-17-2004, 03:46 PM
I checked out that website but it was for a front wheel drive GST Conversion. I assume its simular except the fact that I need a transfer case for mine.
Can anyone tell me or direct me to a site that tells me every single part that goes on the drivetrain for a Manual and a Automatic GSX AWD. I have peiced together more of what i need but i feel like im missing something.
Parts needed:
Brake/Clutch Pedal Assembly
Transmission/Transaxel Assembly (Im not sure how many splines i need)
Transfer Case (I think I can match a 22 spline with 22 spline Trans)
Back Plate (adjustment May be needed)
Clutch Assembly
Clutch Cables
Shift Kit
Clutch Master/Slave Cylinder
Flywheel
Clutch Fluid Line
Cable Hold Downs and a Firewall Gasket
Flywheel Crankshaft Bolts
Convert automatic to manual transmission heywood123 Aerostar 1 07-21-2007 11:25 PM
Need Help with Automatic Tranny. TranceRx7 Engineering/ Technical 2 07-21-2005 09:10 AM
Need help with automatic transmission.... yhwhfirst Montero/Shogun/Pajero 0 01-24-2005 04:18 AM
Automatic into Manual CamBoy Camaro Discussions 4 04-17-2004 06:02 PM
need help installing SR20DET into a 96 sentra sirimport Sentra | 200SX (USDM FWD) 0 01-27-2003 04:46 PM
