Old 01-16-2004, 07:50 PM
russ_westrem russ_westrem is offline
code 22 only at idle
i have a 95 tahoe 5.7 with 100 k miles. at idle my check engine soon light comes on then goes off once i start moving again. the code is 22. thw throttle position sensor. i checked the sensor with an ohm reader and it checked ok. what could be my problem.
Old 01-16-2004, 08:10 PM
brooster brooster is offline
Re: code 22 only at idle
Ohm meter is the wrong way to go. Check TPS voltage key on engine off. I believe the signal wire is blue, but the easy way to find out is unplug the TPS. Check each wire. One will be close to 5 volts. Turn off the key check the other two with the ohm meter. The one closest to 0 or infinity is ground, the other is the signal wire. Plug the connector back to the TPS. Turn the key on. Voltage at signal wire should be around .5-.6 volt. If you or someone else has readjusted the idle lower to compensate for vacuum leak (throttle body gasket), the minimum TPS voltage may be too low.
Old 01-16-2004, 08:11 PM
Bronco2 Bronco2 is offline
Check the TPS voltage output at closed throttle-I think it should be app. .5 volts at idle and 4.5V at WOT. Resistance readings [ohms] are not always accurate due to temp. changes,etc.
Old 01-16-2004, 08:14 PM
well i know for a fact its not the tps because i also bought a new one and still had the same problem. and i also reset the computer after i installed it
Old 01-16-2004, 08:31 PM
brooster-just to help with the diagnostic on this-"the wire that reads 0 or infinity is the ground"-not causing trouble,but that seems to be a opposing statement. 0 ohms is a perfect connection,while infinity means no connection.Agree with the restof the diagnosis
Old 01-16-2004, 09:27 PM
Depends on which ohmeter you are using
02 Trailblazer rough idle and check engine light rainmaninwa TrailBlazer | Trailblazer EXT 4 01-08-2010 10:02 AM
91 escort only runs when i pump the gas hal97321 Escort 3 03-23-2009 06:51 PM
Engine will only idle for 5-8 seconds..Help me! jimmycrackorn Legacy / Liberty / Baja 3 10-10-2007 08:45 AM
P0304 code, rough idle, better since code charlie3 Contour 5 07-05-2006 12:26 PM
HELP 86 maxima only idles cmarr Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 6 02-25-2005 10:36 AM
