Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Maintenance
Maintenance Discussion about maintenance issues.
Old 01-16-2004, 08:46 PM
skylinetofast skylinetofast is offline
Send a message via Yahoo to skylinetofast
driveshaft????????????????
HI there,
When i put my r32 in gear is feels like the drive shaft the driveshaft is jerking. I can feel it through the the floor boards. When I really can notice, just when I am daily driving to work and back. Is this normal.
Old 01-18-2004, 10:56 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: driveshaft????????????????
To the Skylines use a CVs or Universals in the driveshaft?
It sounds like a worn out universal, common problem on well aged RWD cars.
Either that or a lose gear box or engine mount, its possible the rubber has torn away and the engine/gearbox is swinging around.
Its also possible, altough extremly unlikely that the diff is badly worn and about to pop, but they are exremely strong, and take one hell of a lot of abuse.
Old 03-14-2004, 05:28 PM
Doughnutdemon's Avatar
Doughnutdemon Doughnutdemon is offline
There's a U-joint just behind the gearbox, as the axle is in two pieces, one short piece out of the box, the other longer piece to the diff. Maybe that's bad, or the mounting and bearing at the U-joint is bad.
Driveshaft replacement how to... 91g20 Maintenance 7 10-30-2004 04:17 PM
Way to check driveshafts? Motion500 Engineering/ Technical 5 03-18-2002 09:51 AM
Driveshaft queries SpeedAddict Performance 1 11-09-2001 03:49 PM
p10 driveshafts ky_infiniti2000 General 8 10-07-2001 07:03 PM
Carbon Fiber Driveshaft Shooter Boy General Discussion 15 09-10-2001 02:25 AM
