Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > General
General news, articles, other.
Old 09-30-2001, 07:06 PM
ky_infiniti2000's Avatar
ky_infiniti2000 ky_infiniti2000 is offline
Send a message via ICQ to ky_infiniti2000 Send a message via AIM to ky_infiniti2000
p10 driveshafts
I was just looking @ http://www.driveshaftshop.com and started wondering if the sentra se-r driveshafts fit the P10. If not, where can we find stronger aftermarket driveshafts?
courtneyb
imma building a monster
Old 09-30-2001, 07:28 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
Well, unless you are looking at building up a AWD primera i think you meant axles instead of driveshaft Anyways to asnwer your question, the axles on the G20 and se-r are different. You could always use an SE-R transmission and run the beefier SE-R axles, but I'm not sure how much work that would require. My guess is you would need to swap over the hubs too, and i'm not sure if that is possible, or how much work or fabrication that would entail (sp?). Hope this helps.
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 09-30-2001, 09:35 PM
FlossinPrimera FlossinPrimera is offline
Send a message via ICQ to FlossinPrimera Send a message via AIM to FlossinPrimera Send a message via Yahoo to FlossinPrimera
Did you notice that they would make custom axels (half shaft assemblys)
1994 Infiniti G20 5 speed (rebadged as Nissan Primera)
K&N, Enkei Type 11 GML, JVC KD-SH55 Digifine, Pioneer Pear-mica components, 2 12" round things that bang and a 400W amp to make them bang. Coming soon: ACT clutch, new half-shafts, HKS superform springs, KYB AGX adjustable shocks, $tillen STB, 17" König Toxxins with Yokohama Parada Tires (P215/40R17).
http://gforces.streetracing.org/
"I wish Captian Archer was as much as a racial bigot as Captain Kirk"
-Burt Weed
Old 09-30-2001, 10:26 PM
P10DET's Avatar
P10DET P10DET is offline
Actually, if you're going to be technical, both are wrong. Technically they are called halfshafts.
No you can't.
FWIW the SE-R halfshafts are no beefier. Remember, I have both an SE-R and a G20. Also, the CV joints can be interchanged. It would be easier to change them than the hubs, but there is no need.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 09-30-2001, 10:38 PM
P10DET's Avatar
Re: p10 driveshafts
courtneyb
You don't need heftier halfshafts. They are not a weak link in the SR20 drivetrain. I've only heard of 2 broken halfshafts on SR20 powered cars in the last 5 years and almost a thousand subscribers to the SE-R Mailing List.
Long before you need heftier halfshafts, you will need to upgrade your gearbox. Right now that means cryo treating and shot peening the input shaft and third gear at minimum - best to do all gearsets.
Mike Kojima was trying to get Quaife to make a gearset for the USM SR20 gearboxes, but they didn't think there was enough market.
So, don't waste you money on custom halfshafts. Even the stock ones hold up to 500 hp monsters.
What are you building.
George Roffe
Houston, Texas USA
00 328i
Old 10-01-2001, 12:53 AM
JustinP10's Avatar
Originally posted by P10DET
No you can't.
Yes, you're correct. I should have said halfshafts, I'm stupidm, I wasn't paying attention . As for the hubs, I wasn't sure if they were interchangable or not. I guess that explains why Jason Garrett Young (sp?) did the frankenstein half-shafts for his G20? I was just thinking that if the aftermarket halfshafts were stronger, it'd be a better alternative than the frankenstein ones on a very high hp car. And I figured they wouldn't fit into the G20 hubs, because the G20 halfshafts are larger than the SE-R ones, I thought? IIRC my G has a 36mm nut on the end of the halfshaft, where the SE-R has a 32mm one, don't know exactly what that equates to as far as a size difference of the shaft though? Arn't the splines going into the tranny different too?
Justin McClanahan
95 G20
Old 10-01-2001, 05:44 AM
P10DET's Avatar
...And I figured they wouldn't fit into the G20 hubs, because the G20 halfshafts are larger than the SE-R ones, I thought? IIRC my G has a 36mm nut on the end of the halfshaft, where the SE-R has a 32mm one, don't know exactly what that equates to as far as a size difference of the shaft though? Arn't the splines going into the tranny different too?
The splines and the threads for the nuts are part of the CV joint and not the shaft itself.
George Roffe
Houston, Texas USA
00 328i
Old 10-06-2001, 08:48 AM
here's a thought, just go buy some new half-shafts from Infiniti, take them apart and have them cryo treated.
-Burt Weed
Old 10-07-2001, 06:03 PM
P10DET's Avatar
You could, but why waste your money?
George Roffe
Houston, Texas USA
00 328i
Driveshaft replacement how to... 91g20 Maintenance 7 10-30-2004 03:17 PM
WTD: Trade my 93.5 P10 Grill for your 94-96 P10 Grill??? WinterG20 Classifieds 1 05-13-2002 09:36 PM
slightly modified japanese p10 grill on my P10 WinterG20 Cosmetics 7 03-28-2002 09:40 PM
AWD Primera p10 VS. FWD P10 GoodJuan Suspension 5 10-17-2001 09:41 PM
Carbon Fiber Driveshaft Shooter Boy General Discussion 15 09-10-2001 01:25 AM
