Old 01-14-2004, 10:42 PM
LPcatcher01 LPcatcher01 is offline
Send a message via AIM to LPcatcher01
Eclipse problems, HELP!!
I have a 95 Eclipse 2.0 DOHC. And its running like shit right now. When i drive the car, it backfires through the intake(not stock) and hesitates a lot! Horrible excelleration and idles kinda crappy. Any ideas? I was thinkin there is(are) a valve(s) stuck open? head rebuild?
Old 01-15-2004, 01:10 AM
89Turbo944's Avatar
89Turbo944 89Turbo944 is offline
Re: Eclipse problems
What are your mods, millage?
Old 01-15-2004, 08:52 AM
mitsu_eclipse95gst's Avatar
mitsu_eclipse95gst mitsu_eclipse95gst is offline
For some reason my friends RS intake backfires so he cleans his filter......for some weird reason it wont backfire for like 2 months after cleaning. CRAZY
Old 01-15-2004, 03:07 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: Eclipse problems, HELP!!
What is wrong with it? Is it too high to low does it surge???
For Sale 98 Eclipse GS, 5 spd
Old 01-15-2004, 03:52 PM
the idle bounces(in park). And say when i sit at a light or stop sign for a while(car in drive with the foot on the brake), the car shakes and seems to try and jump forward repeatedly. Also, the backfires are most severe and occur most often in the lower gears.
Old 01-15-2004, 05:43 PM
ashah000's Avatar
Welcome to the club, you have Idle Surge
It sucks if you have an auto, because it will push the car while you are on the brakes, I have a manual so i dont have that problem. You can put the car in neutral at the light so if it surges it wont do anything, it will just rev the car. But that is a pain in the ass.
I have blocked off the egr valve, and cleaned the throttle body. They did not solve the problem. But they helped a lot. Mine has been surgeing a lot more lately i think it is cause of the cold weather DAM MICHIGAN.
Check this link out...
http://www.dsmtuners.com/forums/show...6855#post16855
Old 01-16-2004, 04:19 AM
DrivECRasH DrivECRasH is offline
try changing the BISS? base idle set screw or some crap.. heh..
my car surges a little, but only right after i cold start it.. then again, i have a rather annoying lifter tap right after i cold start.. and the head is 2 months old, and i just replaced 2 lifters a few days ago.. i hope it shuts up.. one of them was badly damaged. Not sure if it was defective with the new head, or i have an oil delivery problem.. *shrug*
anyway, good luck =D
Old 01-16-2004, 10:01 AM
kjewer1 kjewer1 is offline
AF - Advisor
Idle surge doesnt explain the backfiring though...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 01-19-2004, 12:44 AM
So, its not an idle surge??.....
Old 01-19-2004, 02:44 PM
ashah000's Avatar
Re: Re: Eclipse problems
No it is idle surge, but there is another problem that is causing the backfiring. You might want to try doing a couple of searches on backfiring.
Old 01-19-2004, 03:15 PM
imtheoneandonlyD's Avatar
imtheoneandonlyD imtheoneandonlyD is offline
Send a message via AIM to imtheoneandonlyD
for the idle problem it sounds like the throttle posiyioning sensor. i had the same problem with my 98 eclipse rs. cost about
Pictures of the Truck
Old 05-18-2004, 11:38 PM
96gsn 96gsn is offline
Send a message via Yahoo to 96gsn
check your plugs they might be bad or gap to big, I had the same problems when I put a set of bosch pltnm. plugs, the guy at the auto store gave the wrong gap size to me and after about a week my car would start to back fire and idle funny, so I took my car to a mitsu dealer and they told me it was the plugs causing all the problems
Old 05-18-2004, 11:58 PM
bigdaddyrob1 bigdaddyrob1 is offline
The surge is due to a TPS (throttle positioning sensor) It is notorious on Talons and Eclipse. You can adjust the screw to allow more/less air. It will lower you idle and stop the surging.
Old 05-19-2004, 06:09 PM
duckydsp's Avatar
duckydsp duckydsp is offline
Also think about a misfiring on one of the cylinders.
DSF
1998 Green Mitsubishi Eclipse GS- Vibrant Ram Intake, Greddy Evo2 cat-back, front and rear strut bars.
2 Kicker L7s, amp coming soon
17" white Motegi RT5 rims, Quwhees 12-piece wide-body kit will be put on....... someday
Old 05-19-2004, 06:14 PM
ashah000's Avatar
Little old
96 Eclipse Rs Non-turbo Vacuum problem. donidavis Eclipse Problem Diagnosis 27 08-29-2010 09:07 PM
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd '99EclipseProblems Engine, Transmission and Drivetrain 6 09-13-2009 10:03 PM
95 eclipse gs blue smoke won't start hcruz32 Eclipse Problem Diagnosis 1 03-20-2009 09:36 PM
eclipse problems talontedEcLiPsE Off-Topic 5 08-06-2003 06:40 PM
Eclipse Problems? EclipseMan Off-Topic 0 11-02-2002 12:40 AM
