Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 01-14-2004, 08:59 PM
erchapma2003 erchapma2003 is offline
2000 tacoma Supercharger blew out my cats at 85k!!!!
Hi,
I put a supercharger on my 2000 Tacoma 3.4 V6 at 25k. Dealer installed
with no other injector kits etc. Basically I was told this was all I needed.
Now I am at 85k and my engine light came on. Toyota told me my whole exhaust crystalyzed and both cats blown. Now a $4k job !!!. So I took it to Meineke. They replaced both cats for $1k. Now 2 weeks later my engine light comes on again and exhaust leak. Turns out the o2 sensor broke which turned my new cats to dust and voided my warranty. Meineke say's that after they replace the cats again and new o2 sensor they may not be able to warranty it because of the supercharger.
I have always taken my ride to the dealer until they tried to rape me with the cost of whole exhaust system. My question is has anybody else had a similar experience? Also, shouldn't Toyota recomend a MUCH BETTER EXHAUST SYSTEM before selling a supercharger? Obviously the stock exhaust can't handle the heat !!!!!!!!!
So I am enraged with Toyata right now because I bought this Tacoma for reliablilty and now I am worried about the engine at 85k ??
Any thoughts or advice would be greatly appreciated !
thanks in advance....
Old 04-20-2004, 08:39 AM
evilmind evilmind is offline
you are paying way to much. you can replace every thing for under 1k. you cad buy direct fit cats for about $150 at www.summitracing.com or call 1-800-230-3030 , headers for about $350, and mufflers range from about $50-$80. get it all together yourself and if you cant weld it, mark it and you can find a shop to weld it together for about $50. i found that pacesetter headers to be cheap and work well. mufflers are for you to judge, they all sound different but any will work. make sure you get everything with the same inlet /outlet size 1.5,2.0,2.5 etc. your o2s most likely are dealer only, but with all this replaced you should be good to go.
Old 04-20-2004, 10:50 PM
superjoe83 superjoe83 is offline
Send a message via AIM to superjoe83
Re: 2000 tacoma Supercharger blew out my cats at 85k!!!!
you may want to ask this question over at www.yotatech.com a lot of people with taco's and 4runners run superchargers over there, and would be able to answer your question better, ive never heard if this problem over at yotatech
If it aint broke, fix it anyway
2000 Tahoe LT Fuel Pump, Cats and Door Actuator ediesel_b13 Tahoe 0 05-14-2010 10:36 AM
Accident, Blew Out Engine on 2000 Durango madisoks Durango 0 03-03-2005 11:16 AM
2000 Z71 Blew Out Rear End AlaskanZ71 Silverado 2 09-16-2004 05:42 PM
Valvoline blew out my heater core!!! Hawk45 S-10 6 09-14-2004 04:03 PM
Tacoma Supercharger? artilla Tacoma 5 01-16-2004 09:11 PM
