Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 01-14-2004, 03:33 PM
muhaimin786 muhaimin786 is offline
wheel nuts for alloy wheels
is it possible to use the wheel nuts on my steel wheels for peugeot alloys. I have a N reg Peugeot 306 1.6 XR with 14" wheels. I have 14" alloy wheels i would like to put the car
Old 01-14-2004, 04:38 PM
Grant@Tirerack's Avatar
Grant@Tirerack Grant@Tirerack is offline
You would need to check with the wheel maker to see what hardware will work safely. Either that or take one of the wheels and the nuts down to a local shop where they can test fit them together on the car. Most alloy wheels will use nuts that have a different seat and length than those used on steel wheels. They may or may not work. The only way is to check how much thread is in contact with the nuts and that the nuts seat on the wheel correctly.
Grant
Your personal contact at The Tire Rack
1-877-522-8473 ext# 313
fax# 574-236-7707
email: [email protected]
Old 01-15-2004, 07:07 AM
thanks i thought as much
HELP: 16" alloy wheels VS 17" alloy wheels traders008 Tires and Wheels 1 11-13-2005 12:25 AM
center wheel caps for alloy wheels katschmitty Off-Topic 2 12-26-2003 09:45 AM
Alloy wheels lug nuts colespark 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 3 10-23-2003 02:00 AM
what wheel lugs for 00Si wheels on 00 LX? filmfiend81 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 10 01-16-2003 01:27 AM
