Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-14-2004, 12:51 PM
pawnpace pawnpace is offline
89 Camry, Turn Indicator Switch does not return after turning
Dear Fourm,
I have an 1989 Camry (4 Cyl). The turn indicator switch does not return back to it's normal position after making the turn. I've tried to look at the design of the indicator system. I see that near the right side of the steering there is a small spring that gets locked into position when the indicator is turned up or down. But as the steering is moved the hub on the steering tries to kick the lever into it's original position but the system does not respond. I have to manually move the levers up and down for turning off the indicators. I believe that the spring has lost it's tension and has shrunk from it's original size. Please help me out!
Thank You,
-Jim.
Old 01-14-2004, 06:52 PM
Joe W Joe W is offline
Re: 89 Camry, Turn Indicator Switch does not return after turning
I'm not absolutely certain about the '89,but this generally requires a switch replacement.
Brake pedal does not return bhw33191 Caprice 8 08-29-2009 10:06 PM
'97 Astro: Turns Over But Does Not Start wew M Bodies 4 08-04-2006 01:10 PM
Engines turns over but does not start jspinhirne Excel 0 02-15-2006 10:13 PM
93 Regal-turning off engine does not unlock power doors Johnny R Regal 7 12-29-2004 02:47 PM
Changing the Combo/turn indicator Switch Ichimonban Accord/TSX/Accord Hybrid 0 05-16-2004 07:09 PM
