Old 01-14-2004, 10:48 AM
rockford0384's Avatar
rockford0384 rockford0384 is offline
regular or synthetic oil
Alright my car has 149xxx miles on it. Its a 97 gtp and Im not sure if i should put synthetic in it or regular oil in it. I want to change the oil and oil filter for my trans. I have about 9 quarts of synthetic oil (maxlife dextron 3). Ive been wanting to put it in but im scared it might screw it up. I hate soft shifts... and im affraid this stuff might make it shift soft. It says for higher mileage vehicles. But highly not recommended not to use in new or rebuild trans's.
let me know what all your opinions are.
1996 Ranger with 249,xxx miles on it...
was my beater now my daily driver,
still trying to figure out how that happened
99 MXZx 440 SNO PRO
Forsale
89' Honda TRX 250R
Old 01-14-2004, 03:57 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
If your talking bout the trans fluid then stick with the stock fluid. The Syn. will be to slippery, and you'll more then likely start noticing the trans slipping.
Old 01-14-2004, 04:12 PM
GTPJeff GTPJeff is offline
If it's dextron 3, weather it's synthetic or regular tranny fluid.. It has to have a specific coeffecient of friction..
If you've got the fluid already, put it in.. It won't hurt.. But synthetic tranny fluids greatest claim to fame, are their shear strenth, and resistence to heat.. Unless you're racing or towing sythetics can be cost prohibitive...
Or, if your like me and only want the best for your baby.. You'll use synthetics through out ..
Building an 87 Mustang GT..
351 bored and stroked to 383 ci..
Brodix M2 Track 1 Heads..
Turbonetics T76 Ceramic bearing Turbo..
Dynamic Racing Transmissions C4..
Car was a Whipple Supercharged 302..
Ran 11.6's at 120 on street tires..
Sould run 9.30 at 150 when done..
Now you know why I've got a Supercharged Grand Prix..
Old 01-15-2004, 02:14 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: regular or synthetic oil
I agree, Always has been said that syntethics have more resistance to thermal breakdown and longer usefull life, meaning, will behave as expected on a larger high temperature expectrum. And it is correct, whether is type F, ATF, Mercon 3, Dexron, Dexron/Mercon 3, etc, does not matter if syntethic or not they must have the same viscosity/friction specs than the std petroleum based oils. I was told once tought that the european syntethics are somewhat better because they are based on Graphite or similar materials and not necesarilly petroleum
How long before my synthetic oil needs to be changed? imnotnotjoe General Discussion 2 07-07-2009 08:38 AM
Swithcing fr/ Regular oil to Synthetic oil... comments? Shpyder Off-Topic 17 06-22-2004 06:21 PM
Synthetic vs Regular motor oil rxs-s 2002 Integra 2 02-23-2004 09:08 PM
