Old 01-14-2004, 08:20 AM
jomel jomel is offline
Unhappy 1999 Grand Prix Gt W/little Heat
I need help. I have a 1999 Grand Prix GT Sedan with the 3800 Series II engine with 58,000 miles on it. It has very little heat. I flushed the cooling system twice, installed a new thermostat (even though the engine temp was fine) and fresh coolant. The radiator and overflow are full. The intake manifold has a leak and the coolant that comes out steams off and never leaves a puddle on the ground. I have opened the cooling system check valve and their is no air in the system. Has anyone else experienced this problem. I understand that the leaking intake is beginning to be a trend with the Series II engines (it was repaired once under warranty as were other problems that are problems once again - of course not under warranty now!). Thanks for any help.
Old 01-15-2004, 02:51 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Re: 1999 Grand Prix Gt W/little Heat
What you mean by little heat? You mean the heater (AC/Heater)? I do not understand what you want?
Old 02-20-2004, 03:49 PM
BDittus BDittus is offline
The GM 3800 Series II suffers from a plastic intake manifold leak which is prone to break down around the ERG stove pipe and flood the engine and hydro lock the block. GM has an upgraded instake manifold design which has a brass sleeve to protect the plastic from breaking down.
Only fix is to replace this with the updated part, as well as new coolant, new plugs, and in my case the MAP sensor as well. Cost of job for me was about $550.00
99 Grand Prix acceleration problems MConder Grand Prix 7 12-11-2010 10:08 PM
1990 Grand prix le problem Erik23512 Grand Prix 1 11-05-2010 12:14 PM
1997 grand prix anti-theft system components Konstantin Grand Prix 8 10-13-2010 10:20 AM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 08:57 AM
1999 Grand Am nanatraci Car Audio 5 06-19-2009 07:00 PM
