Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 01-13-2004, 11:15 PM
ColeIketani's Avatar
ColeIketani ColeIketani is offline
Send a message via AIM to ColeIketani
BTW does anyone know how to tune more hp from an NA without dropping in a turbo?
well???
i love starting threads that way
2003 Hyundai Tiburon: Injen CAI, Mussa Single Exhaust, Sparco Four Point Harnesses, RRM Front and Rear Strut Bars, 22mm Rear sway bar, Shark Racing Pedals, Painted Rims.
Saving for: Either Big Brake Kit, lines etc, Tien Coilovers Sparco Speed Seat for driver side.
Old 01-14-2004, 12:23 AM
Adam_Hunsicker's Avatar
Adam_Hunsicker Adam_Hunsicker is offline
Re: BTW does anyone know how to tune more hp from an NA without dropping in a turbo?
start with either SRI (Short Ram Intake) or CAI (Cold Air Intake)... that's always the best mod to put on first... Follow that up with a good catback exhaust system (such as the one released by Mussa Racing)... if you're a true tuner then the next place I'd go is for traction and less rotating mass... in other words get yourself some bad ass tires mounted on the lightest rims you can find (10-12 lbs each w/o tire is usually pretty decent but I've seen some EXPENSIVE racing wheels at around 7 lbs each!) After that it's time to get into some real money.... go for an engine oil cooling system and, if you're running an auto tranny, a tranny-fluid cooler. Cowl induction/ram air hoods and upgrading your radiator are usually a good idea as well... if you want to check out everything I plan to do to my '03 Tib go to my website at http://www.adam-hunsicker.com and check out the Modifications section under "2003 Tuscani". If you have any other questions feel free to drop me an email at [email protected]
Adam
Black '03 Tib, 2.0, Auto
Old 01-14-2004, 01:42 AM
Thanks man for the info and for the advice, I checked out your page yesterday and saved it on my favorites.
Anyway the reason I asked was that I wanted to tune more hp from my Tib, but I didn't want to install a turbo yet for two reasons, money and turbo lag
Old 01-14-2004, 01:46 AM
btw, I added some pics in my album, check em out Adam!! lol
Old 01-14-2004, 02:06 AM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
wait you have an i-4 auto... ok turbo lag... hmmmm
weight redustion...
back seats out... spare tire out lose teh shit you dont need
what do oyu have in your car as of now?
and what are you willing to spend?
Old 01-14-2004, 09:32 AM
ok well for the moment I'm going to hold of on some of the weight reduction, because I'm still going to need to commute <------- spelling >:-0
Old 01-14-2004, 12:06 PM
1QUICK2 1QUICK2 is offline
IMHO.....Dont waste money on an N/A 4 cyl. Just save the money and turbo it. If you have the right turbo....lag is not an issue. Even if it was, lag will pay for itself on the top end. Put an exhaust on for now because you will need it later, dont buy an intake because a turbo will need a totally different one. Seriously....just save the money until you can do it right.
93 MR2 Turbo-.20 over JE pistons,T3/04E 57 trim w/.63 AR,Intake,Greddy profect b spec 2 BC, APEX'I GT spec exhaust,Apex-i S-AFC, Turbo timer,550cc injectors,HKS trunk mount IC, B&M s/s,SPEC stg3 6puck clutch, TRD springs. Autometer gauges, PCP reverse indiglo gauges. P/P head,Intake, 17" SSR repl, Kaminari front lip and sides.338whp/272lbs tq at 18psi
FOR SALE! email: [email protected]
http://members.cardomain.com/1quick2
Old 01-14-2004, 12:09 PM
well that may be true, but I'm really want the immediate response time from the N/A.
Old 01-14-2004, 12:38 PM
tibby01 tibby01 is offline
if i were you, id save and go turbo, since the beta doesnt respond well to n/a mods but does respond very well to boost.
a few people hve gotten into the 14s without boosting or nitrous though, however, they have easily spent what a turbo system would cost.
CAI
header
exhaust
high grip clutch
bored block
high compression bored pistons
cams to match pistons(you will have a very rough idle though)
haltech fuel system
you could get your crank knife edged and balanced
LSD
port and polish every possible thing
the list goes on and on
here is a thread
http://hyundaiperformance.com/forums/topic.php?t=43221
Old 01-14-2004, 03:58 PM
Thanks for the ideas guys
Old 01-14-2004, 11:08 PM
I understand the concern due to the commute so stick with the things I mentioned above... all of it should be compatible w/your later addition of a turbo except for the intake... but you can do like I did and make one for all of about $35... as far as lag is concerned... don't worry about it. With the auto as soon as you're spooled up your not going to lose boost because you don't have to let off the gas until the race is over.
Adam
Old 01-14-2004, 11:15 PM
that's a damn good point Adam. That makes me think about the turbo a bit more.
On a side note tho, from the NA cars I've gone up against it's been pretty sweet, but this isn't the board for it
Old 01-14-2004, 11:18 PM
just a quick question about your custom SRI, why didn't it cost anything?
Old 01-14-2004, 11:24 PM
because I took the one I had in my Ford Ranger, cut it in half, welded a small piece of tubing I had laying around on it and installed it in my tibby.
btw, I just uploaded two new pics... one for the girls (a pic of me, LOL) and one for the guys (you can figure it out. )
Adam
Old 01-14-2004, 11:49 PM
I saw GO ADAM
Does anyone know how to remove the dash from a 1998 grand am se?????? Kurt_Cobain2003 Grand AM 2 03-14-2004 02:59 PM
Does anyone know how to adjust the clutch? mano77 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 11-12-2003 02:11 AM
does anyone know how to break into one without breakin' the window out? stabilizer7 Fiero 7 08-02-2003 01:10 PM
does anyone know how to make the exhaust more quiet? stabilizer7 Fiero 1 06-24-2003 05:08 PM
Does anyone know how many Cubic Inches the G20 is? slickkedar Engine 2 07-20-2001 08:22 PM
