Old 01-13-2004, 07:59 PM
91stang 91stang is offline
Send a message via AIM to 91stang
Question Autometer Gauge Install
I recently purchased 2 autometer gauges: oil pressure and water temp. both mount into an a-pillar pod. now i have the ground and sender units hooked up on both gauges, the only problem im having is giving the gauges power and light. People have said to go through the fuse box and others have said to splice into the ignition wire for AC power and splice into the stereo for the lighting. i dont know which fuse(s) for the fuse box or which wires for the ignition/stereo. could someone help me out here?
pictures would be VERY helpful
-91 stang gt vert
Old 01-13-2004, 09:02 PM
Re: Autometer Gauge Install
well i got the gauges working, now all i need to do is the lighting. any advice on that? thx
Old 01-13-2004, 09:29 PM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
You can run it either place. The fuse box, or the AC for the stereo. If you flip the lid of the fuse box over, it should tell you there what pods are for ingnition and such.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 01-13-2004, 11:06 PM
hey you're chris' friend craig. he installed the same gauges, but he's offline right now. i tried plugging the wire for the illumination into fuse #4 and they light up, but they dont dim. then i heard if i run it through the stereo they will constantly be on. i dunno, chris said he went through the stereo and they work fine. should i go through the stereo fuse? or splice into the stereo AC? thanks
Old 01-14-2004, 06:48 AM
HiFlow5 0's Avatar
Stanger
OK, here's a pic thanks to my new digital camera. LOL
Position 11 on the fuse box or #1 in pic is a constant power source, don't use that one, it was just for reference. Position 12 on the Fuse box or #2 in pic is the radio fuse, which is a switched ignition slot. That's where I have the positive wire from my gauges hooked up.
-2013 Ford Flex
-1999 Ford F150
Old 01-14-2004, 12:21 PM
well i just ripped apart my gauge cluster and found which wire controls illumination and dimming when the parking lights are on. my hand got mauled during the proccess of taking the harnesses off, but i guess it was worth it. i checked every fuse in my fuse box and none of them worked with dimming, i dunno. i'll prolly just splice into the wire i found or wedge the wire into the harness and tape it up. thanks a lot for the help!
Old 01-15-2004, 11:25 PM
1990LXDropTop 1990LXDropTop is offline
Send a message via AIM to 1990LXDropTop
I told you gauge install was a pia Took me a while to figure it out too. Good luck!
1990 LX Convertible:
http://www.cardomain.com/memberpage/810219
Edelbrock Performer heads/intake, crane 2040 cam, and all the bolt ons...
Old 01-15-2004, 11:38 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
i actually spliced into my headlight dimmer switch so my gauges dim when i dim the dash lights.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 01-18-2004, 04:44 PM
installed. thanks.
Need help with tachometer install! AHHKILLA Eclipse 2000+ 0 05-03-2009 10:04 PM
Autometer Gauge Install Question 03impala9c1 Grand Prix 0 03-11-2007 02:55 PM
Help needed installing autometer gauges jason41 Engineering/ Technical 1 03-03-2004 01:17 PM
IDIOT needs help installing first autometer gauge, hurry b4 i electrocute myself grasshopper Engineering/ Technical 4 11-25-2002 09:54 AM
installing autometer gauges j.fuggi '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 01-30-2002 12:52 AM
